Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Mine's GTR cluster on ebay
    RixR32's Avatar
    Sep 2006
    Sarnia, Ont
    770
    Looks like a good price for you GTR guys......
    Mines 320k....
    http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
    I usually see these upwards of $300
    Rick
    '89 Gts-t.
    '94 Mitsubishi Pajero Super Exceed 2.8TD LWB
    '10 Mazda 3 Sport Hatch
    '00 Freightliner - The Money Maker
    GTRCer SkyLizzle's Avatar
    Jun 2007
    G.T.A
    763
    Damn you Nate!!! you got it for such a good price!
    1992 BNR32 Skyline GT-R
    Quote Originally Posted by bignate View Post
    If you are too lazy to search the site for info you are certainly too lazy maintain a 15+yr old JDM car.
    Ass, grass or cash Nobody Rides for free!!
    GTRCer LivingMovie's Avatar
    Oct 2005
    La Ronge, SK
    192
    Quote Originally Posted by SkyLizzle View Post
    It might not have worked on your car.
    Speedo's cant be interchanged from gtr's before 08/91 and after.
    Does that make sense?
    I nearly bought it until I remembered mine is an 89 :hit_head:
    1989 BNR32 / R34 N1 RB26 / Autronic ECU / HKS GT2540's / Ohlins Suspension
    GTRCer bignate's Avatar
    Jan 2007
    Fergus, Ontario
    2,296
    dammit mine is a 90. I will have to see if I can make it work when it arrives. Worst case she resells.
    RixR32's Avatar
    Sep 2006
    Sarnia, Ont
    770
    If it doesn't work you should make at least twice your money back....
    BTW why wouldn't it work? Just curious.....
    In GTS's it works if you replace the whole cluster and not just change the speedo's....
    Rick
    '89 Gts-t.
    Jan 2007
    Fergus, Ontario
    2,296
    Quote Originally Posted by RixR32 View Post
    Rick
    Well yea thats what i figured. I think I will be able to make it work though.
    Jun 2007
    G.T.A
    763
    Nate,
    I call Dibs if it wont work in your car i am a 91 soo "Crossing fingers"
    RixR32's Avatar
    Sep 2006
    Sarnia, Ont
    770
    Nate did you receive this yet? I've been kind of experimenting with them and if it doesn't work I'm pretty sure I've figured out how to do it. The info I was given was false as to it working if you swap the whole cluster. My tach didn't work, the temp gauge acted funny, no low oil pressure light, and Hicas went nuts.
    Here is what I've found out...
    1. The cluster housings are not interchangeable if the circuit boards on the back look different,(Newer one is more blueish color).
    Your car needs to use the original cluster HOUSING and therefore circuit board it was designed with.
    2. If the above is true you have to put the Mine's speedo into your cluster, and put a small piece off of your OEM speedo onto it.
    You'll see the part I mean when you have the speedo's out side by side (it looks like a little black plug, remove it from your OEM and put it onto the Mines, then install the Mine's into YOUR cluster)
    3. Also, if your OEM gauges are the blue faces then you'll have to swap the other gauges into your cluster also, so they match (obviously) I had to do this also
    Compare yours and let me know, I should be able to help you get it working if it is the different one. Maybe take some pics of the backs so I know what one you got, and PM me if you want.
    I'll also post a DIY on this if this works out like mine did.
    Hopefully though you got one that is directly compatible!
    Rick
    ***EDIT - took a pic and added it below. The top cluster is the '92, the bottom is my '89. The top one will not work if your OEM is like the bottom one.
    Note the main differences around the speedos,(attaching screws, plug on bottom left of speedo) this is what you account for when you change the piece I mentioned above.
    Sorry for the long post, but hope it helps. Don't need anyone else removing their cluster about 4-5 times like I did to figure this out!
    '89 Gts-t.
    Jan 2007
    Fergus, Ontario
    2,296
    The mines cluster came the other day. Just snapped a pic of it and looks like the ebay ad was wrong and its a pre 92 cluster. Lucky me!
    dont know whether I want to just drop this cluster in or swap the speedo into mine since i know everything works perfectly. thanks a lot for the post Rick. It would be useful in the FAQ section as I'm sure other people have wondered.
    Apr 2007
    St. Albert, AB
    1,600
    God damn am I jealous, a Mine's 320 speedo for 50 bucks plus shipping!
    1990 Skyline GT-R - Jet Silver Metallic
    It'll run someday
