http://cgi.ebay.com/ebaymotors/NISMO...m140236336875&
Of course, 8 bids at $300USD, reserve is not met....
90 GTi-R , Full Restoration Project
91 GTi-R , Full Race Project
http://i115.photobucket.com/albums/n...phic2short.jpg
Yeah, yeah........;-)![]()
saw it when it first went up
opening bid was 1 dollar
its a pretty pimp block
I wonder what the Reserve is for this thing ? ......$1500-$2000 USD ?
i emailed the seller toask for shits and giggles
when he emails me back ill let everyone know
whats so special about the RRR block in comparisson to the stock block?
It's an all out GT500 race block. It has magical powers.
Well, maybe not, but it is specially developed to work in conjunction with 87mm pistons and the GT crank for 2.8L of displacement.
It probably has more cylinder wall thickness then a OEM, and possible 24U block, at 87mm bore...
Creme of the crop rb26 block.
rough numbers
05U - 92 MM between outside of the bore liner
24U - (N1) = 95MM little bit of gallery changes
RRR - (GT) = 98MM which has some fancy dancy things inside
Though i can only guarantee the 05U number.
I would not be surprised if there was a 8k reserve.
$1600 USD and Reserve still not met......
There is however 1 problem that people here should consider. It is something that I have had the privilage to have learned in the past month or so and continue to be reminded of it, some days up to 2 times a day, or more.
Because this block is on Ebay, it must be a Nismo block that didn't pass quality control, or is a knock off or possibly fake, or is from a 'bad batch', or was constructed using sub-standard materials and even though, it may be consecutively serial numbered, it has a lesser quality than the 1 before it and the one after it and it probably doesn't maintain 'trueness' throughout it's bores and journal sections.... and that is why it is on Ebay.![]()
