Headlight bulbs for GTS-t
This is a sticky topic.
  • #31
    exactly what I was about to say.. series 2 headlights are different
    Marc-André
    _________
    2.2L RB20 GTS-T
    • #32
      Originally posted by linedriver View Post
      hey greg, if your car is 91 or newer, dont you use H1 bulbs or something?
      yea, i tried an h1, it fits nicely. but, h1's only have 1 prong on the back so how do i get around that? run the seperate ground? or is there some jdm version h1c or something odd?
      I think someone on here would be going through this conversation sooner or later, so now at least everyone knows.
      1991 Skyline Gts-t Black - Crashed,Fixed,Parted. Still out there.
      1992 Skyline Gts-t White - Almost ready to abuse.
      • #33
        i think the H1 bulbs are run similar, if not the same as a regular H3. the prongs deal with the positive while the base of the bulb is grounded out. check out the base of the headlight, it should have a grounding prong on there
        whats going to power my skyline come spring?
        • #34
          Yea, thats exactly how they want to work, but i have no metal clips to lock the bulbs in
          • #35
            i have a spare set of headlights if you want to take the clips out of them. they were a mixed set of headlights cause one of them took H3C bulbs while the other took H1 bulbs, but the clips should be the same if not similar.
            • #36
              omg yes. when can i get these???
              • #37
                You guys can just get a set of HID Conversions of me , I carry both H1, and H3C and H4 for all R32 Skylines as well as R34 and R33
                • #38
                  I would but im selling the car, and wont see this money back.
                  • #39
                    I just read through this topic and it seemed there was still some speculation around the bulbs so I just wanted to confirm that on a 92 gts-t projector for the low beam it was indeed an H1 bulb that I just swapped out on my car.
                    • #40
                      yes.
                      and now i need the adapter that the h1 bulb plugs into. damnit this is becoming a pita.
                      • #41
                        aww ur selling ur skyline just after u get it all fixed up?
                        • #42
                          This is absolutely true.. My bulbs blew out from last nite, i then looked for my spare h3c but id didn't fit, tried to custom make an h3 but the hole is too small.
                          I then realize it has an adapter that holds H1 bulb..
                          • #43
                            I found its prety much a crap shoot, different skylines have different bulbs, its pretty random from what i've seen.
                            And yes the skyline is already sold. Got more than I wanted so I'm happy, new owner is very happy as well.
                            • #44
                              So does anyone know if a 55w 12V OEM bulb can be swap with 100W 12v without burning any wires?
                              • #45
                                stick with a 55 to be safe.
                                I actually threw a 55 watt turn signal bulb where a 21 watt shoulda been, the bulb burnt out in 3 hours, so maybe its just the bulb that will die?
