exactly what I was about to say.. series 2 headlights are different
Headlight bulbs for GTS-t
This is a sticky topic.
Originally posted by linedriver View Posthey greg, if your car is 91 or newer, dont you use H1 bulbs or something?
I think someone on here would be going through this conversation sooner or later, so now at least everyone knows.
1991 Skyline Gts-t Black - Crashed,Fixed,Parted. Still out there.
1992 Skyline Gts-t White - Almost ready to abuse.
Originally posted by gregrego View Postyea, i tried an h1, it fits nicely. but, h1's only have 1 prong on the back so how do i get around that? run the seperate ground? or is there some jdm version h1c or something odd?
i think the H1 bulbs are run similar, if not the same as a regular H3. the prongs deal with the positive while the base of the bulb is grounded out. check out the base of the headlight, it should have a grounding prong on therewhats going to power my skyline come spring?
Originally posted by linedriver View Posti think the H1 bulbs are run similar, if not the same as a regular H3. the prongs deal with the positive while the base of the bulb is grounded out. check out the base of the headlight, it should have a grounding prong on there
Originally posted by gregrego View PostYea, thats exactly how they want to work, but i have no metal clips to lock the bulbs in
i have a spare set of headlights if you want to take the clips out of them. they were a mixed set of headlights cause one of them took H3C bulbs while the other took H1 bulbs, but the clips should be the same if not similar.whats going to power my skyline come spring?
Originally posted by linedriver View Posti have a spare set of headlights if you want to take the clips out of them. they were a mixed set of headlights cause one of them took H3C bulbs while the other took H1 bulbs, but the clips should be the same if not similar.
Originally posted by JzGarage View PostYou guys can just get a set of HID Conversions of me , I carry both H1, and H3C and H4 for all R32 Skylines as well as R34 and R33
Originally posted by Godzooky View PostI just read through this topic and it seemed there was still some speculation around the bulbs so I just wanted to confirm that on a 92 gts-t projector for the low beam it was indeed an H1 bulb that I just swapped out on my car.
and now i need the adapter that the h1 bulb plugs into. damnit this is becoming a pita.
This is absolutely true.. My bulbs blew out from last nite, i then looked for my spare h3c but id didn't fit, tried to custom make an h3 but the hole is too small.
I then realize it has an adapter that holds H1 bulb..
I found its prety much a crap shoot, different skylines have different bulbs, its pretty random from what i've seen.
And yes the skyline is already sold. Got more than I wanted so I'm happy, new owner is very happy as well.
Originally posted by flipridah17 View PostSo does anyone know if a 55w 12V OEM bulb can be swap with 100W 12v without burning any wires?
I actually threw a 55 watt turn signal bulb where a 21 watt shoulda been, the bulb burnt out in 3 hours, so maybe its just the bulb that will die?
