OK and now the continuation of my other light bulb replacement threads:
How To: Change The Climate Control Bulbs
How To: Change The Bulbs Above Your Steering Wheel
Welcome to "How To: Change The Power Window Switch Light Bulb"
Remove the Power window switch assembly using a thin dull tool like a butter knife. Insert under the front edge of the switch assembly (the side closest to the hinge on the door) pressing towards non hinge side of the door. There is a little metal clip that springs back. As you do this pull up and it should come out pretty easily.
![](http://img509.imageshack.us/img509/1203/hpim0662iy9.jpg)
Take out the 4 screws that hold the window switches in and pull the assembly out.
![](http://img134.imageshack.us/img134/3460/hpim0660rh3.jpg)
Now the hard part. The white plastic piece on the back of the switch assembly comes off. There are 4 tabs per side. Only the middle two per side have to be pressed in. I managed it on my own without breaking it but be patient or get help because it's not easy. Once the piece comes off you will see a brown plastic screw in the middle of the circuit board, that is the bulb assembly. Turn it 1/4 turn and pull it out. Change the bulbs with the same Source 2721092's as we used in the How To: Change The Bulbs Above Your Steering Wheel post http://www.thesourcecc.com/estore/pr...roduct=2721092.
![](http://img256.imageshack.us/img256/7913/hpim0661dp2.jpg)
There is no trick to putting to back together. Just snap, screw and pop it back in the door.
