HKS GT-RS turbos
  • Super_Dude
    replied
    Defiantly interesting stuff. I would say his 2530's must have been stuffed but it's impossible to say for sure. Either way, same or differnt, you can't go wrong with either.
  • NismoS-tune
    replied
    Originally posted by Super_Dude View Post
    I've never heard this before and I dont believe it. they are so similar and I doubt anyone had done back to back testing. Some people say they are differnt some people say they are the same. I was told by someone in the know that -5's are 95% of 2530's. The biggest differnce is the oil drain
    SAU when I was hunting for turbos when I could get either for the same price.
    Here's one of the links that had come to mind right away.
    So I've recently replaced my old HKS 2530'S with the GARRETT 2860'S-5. I was instantly impressed with the low down power. I'm still trying to convert the speed into RPM to get a direct comparison. Because the shop that did the power run with the garrett's was a V8 place they didnt realise the RPM...
    Of course, this is the internet. Only some of them had swapped the turbos only between dyno runs and other simply knew stuff.
  • NismoS-tune
    replied
    In perspective, it took me over 2 hours to get the turbos out. Had all the right tools.
  • Super_Dude
    replied
    If you have all the right tools and equipment, it takes less time to pull the engine than take the turbos out.
  • evilgtr
    replied
    Just out of curiousity how long does it take on average to yank the donk out of a R32 GTR provided you have all the right tools and equipment ?
    Iv pulled enough small blocks out before and that's a pretty straight forward but havnt pulled my RB26 before.
  • DJ
    replied
    Its really simple to pull the engine out.People under estimate the rb26 , like you said if you replace the rod bolts ,change the bearings and take care of the oil drive issue , the motor can take big power.But then again if you're going through the hassle of removing all the internals ,might aswell drop in some forged items...
  • shawnr204
    replied
    ya... to put the crank collar on do u need to pull the engine? That leads to another question how hard do u guys find it pulling a rb? Ive heard fairly simple and ive heard haaard as hell lol! if im gonna yank the thing mise well just go balls out and do the whole oil pump, wether its just n1 or a greddy. any other suggestions? As you might have noticed im a NEWB with the gtrs...
  • Sandersb4671
    replied
    You should be safe running stock bottom end but for what it's worth (and we all know what it's worth..) check your oil pump drive before putting everything back together. A good tune will mean nothing if you have no bottom end. It's definitely worth it to throw a $100 dollar collar in there while you're at it
  • shawnr204
    replied
    ya my goal would be to eventually get to 600 wheel. Tell me if im totally stupid here but for this summer i want to get the turbos, required fuel system, run some meth, a very good protune and leave the stock internals for a year... maybe change the rod bolts to arp and the bearings as well... and keep it under 8rpm because i am pretty sure my car hasnt had the oil pump installed (who knows im still yet to get deep in to it should be later this week or next week, but its very fair to assume it hasnt been done!) Right now i have full 3.5 trust exhaust and down pipe, apexi intakes and got it boosted to 1 bar.
  • Super_Dude
    replied
    The 30s lag a bit more but make more power up top then the -5s.
  • NismoS-tune
    replied
    They're easy to find. -5s are a few bucks over $2000 and 2530s are for sale often. The 30s lag a bit more but make more power up top then the -5s.
    What's your power goal? 700ish?
  • shawnr204
    replied
    hmm okay thanks alot guys... i was more so leaning towards the 2860-5's or 2530's if i could get my hands on them... having some troubles finding either, except on ebay the -5's. But thanks solved my problem and question in no time!
  • Super_Dude
    replied
    They are laggy as hell on a 2.6 and shuffle really bad, dont do it. Even on a 2.8 they aren't great.
    On a RB30 they are amazing. responsive and tons of power
    I've been in gt-rs equiped 2.6's and they are terribly laggy. I drive a single turbo gtr with a 4088 that will flow as much as the gtrs's. It is much more responsive.
  • DJ
    replied
    Not many people cause they're laggy on the rb26, they would probably be a better match for a 2.8 or 3.0 rb.
  • shawnr204
    started a topic HKS GT-RS turbos
    HKS GT-RS turbos
    Having troubles finding any threads on people using these turbos on the rb26. Is it a good set up because I dont see many people using them compared to the 2530's or 2860-5's. Thanks in advance!
