My hood is sooo hard to open!
  • RHDskyline
    replied
    Hood pins FTW
  • blkgtr02
    replied
    tensioner inside is worn out usually. sometimes you can bring the clamping piece closer to make it tighter and it'll open with less pull...
  • elroy
    replied
    On my car, the cable sheath would bind into an "S" shape right at the release handle.
    I can hold it straight when I pulled the release, and it releases easily.
    Once it get warmer I'm going to see if there's a mounting bracket missing? Or run some hard fuel line to keep it straight :P
    But yea, check for the line binding right behind the release handle.
  • TheyKilledKenny
    replied
    I read some nissan service reports that said the hood, trunk and door latches should be lubed every 20-40k???
  • leeaspin
    replied
    I have a feeling everybody is just gunna say the exact same thing
  • NerdJuice
    replied
    Originally posted by trickey1991 View Post
    I had this problem...i put some spray lube on the hood latch and let it sit..and fixed it right up..
    +1
    Mine was so bad that when I went to open my hood on a cold day, the plastic handle on the interior of the car broke. So I took some WD40 to the hood latch, let it sit, and I opened it no problem.
  • NeptuneGTR
    replied
    Mines like that too, feels like the cable is gona snap when ever I pop the hood.
  • archaeic_bloke
    replied
    +1 on latch lubrication, will most likely fix it.
  • M13
    replied
    You can lube the cable but sometimes they are just beyond repair. Hit up sponsors for OEM replacement or part-outs.
    The latch could use some WD40 also.
  • trickey1991
    replied
    ya man worked forrrrrrrrrrrrrrr meeee lol
  • Murchie
    replied
    Im going to try this..
  • gtrjon
    replied
    yea this is a common problem with r32s i just man up and hit the weights.
  • trickey1991
    replied
  • Nismo_line
    replied
    i have the same problem i think my problem is that my headlights arnt sitting properly cuz the previous owner had accord lights hacked in so i think my lights are pusshing up on my hood. it is much easier to open when someone pushes down on it when i open
  • Daryl @ RightDrive
    replied
    The R32s always have such hard hood release cables. I'm not sure what the reason is exactly. We do sell new hood release cables if needed.
