Spring is in the air and its time for some more goodies for our sleeping rides!
AMS S.Steel Braided Lines $89 List - GB - $68 CDN!
• AMS Stainless Steel Braided Brake lines replace OEM rubber counterparts
• Unlike OEM lines that swell the AMS S.S. lines do not flex resulting in a firmer pedal feel!
• AMS Lines feature teflon coated lines for durability
• Kit includes all 4 lines (F/R) and retaining clips
AMS Carbon Ceramic Pads Front $68 List - $50 CDN GB
• Proprietary Carbon-Ceramic formulation
• High coefficient of friction
• High resistance to wear at extreme temperatures
• More bite and shorter braking distances
• Integrated shim for maximum performance and quiet operation
• Low dust levels
• Exceeds OEM specifications for stopping, noise, and wear!
• Extended rotor life!
• Slotted and chamferred
• ISO & TUV Certified
• Perfect in conjunction with AMS slotted rotors!
AMS Carbon Ceramic Pads Rear $58 List - $40 CDN GB
AMS SOLID SUB-FRAME BUSHINGS (8 PC KIT) List $125 GB $86 CDN GB
• Replaces leaky and sagged OEM units! (Sag is the end result of worn OEM units and will lead to drive-train imbalances and premature wear in driveshafts and tranny mounts. Reduced handling ability and excessive "wheel hop" are also a problem area with worn OEM units)
• AMS solid aircraft grade aluminum (T6061) bushings replace the OEM rubber impregnated units for a solid foundation
• Virtually eliminates the dreaded "wheel-hop"
• Designed with exacting tolerances
* Bushings should be placed in freezer overnight for ease of installation!
AMS SUB-FRAME COLLAR KIT List $75 - $50 GB CDN
• AMS 8 PC Billet Subframe Collar kits are designed to reduce the dreaded wheel hop and movement in the sub-frame of NA and TT model Zs!
• Replace tired and worn factory bushings with these cost-effective solid units - Installs in less than an hour!
• Billet aluminum construction
• Anodized Stealth Black for an OEM look, fit, and finish
• AMS laser-etched logo
Forms of Payment are Direct Debit Transactions (e-mail), Paypal (add 3% fee), Chq, Money Order, Cash.
PM or e-mail for shipping quotes and provide a full address.
Parts ship usually next business day once payment is confirmed!
Regards,
Vuk@AMS
1(888)888-AMSINC
• Low dust levels
Regards,
Vuk@AMS
1(888)888-AMSINC
