Originally posted by Snake556
View Post
1989-1991 GTR R32 compared to 1992+ GTR R32
Originally posted by Nvdgtr View Postalright thanks, and do u know how I'd be able to check the turbos and also the compression should be 150-170? Correct...
Yes, good compression should be around 150-170. As for checking your turbos, check for any oil on the inside/in your piping and check for shaft play.'03 Ford MustangOriginally posted by kengeroothat's what I thought when I opened the package..
Oil in the piping being the piping that goes to the filters n what not correct? And how would I check for shaft play?Originally posted by Snake556 View PostYes, good compression should be around 150-170. As for checking your turbos, check for any oil on the inside/in your piping and check for shaft play.
Check your I/C piping, and your turbo exhaust piping. As for shaft play, you can bring it to a specialist shop to have your shafts checked/balanced, but you can also check yourself for visible play by seeing if you can move the shaft up/down/left/right by jiggling it.'03 Ford MustangOriginally posted by kengeroothat's what I thought when I opened the package..
^ This man speaks the truth. Aftermarket pumps are rather expensive. But like I said, the stock pumps are fine as long as you're not gunning for mad numbers or bouncing it off the limiter. Saves you some cash that way. Another sort of fix for it is to take your crankshaft and have a new crank collar pressed on that's made to fix the issue. There was someone on here selling them a few months ago IIRC'03 Ford MustangOriginally posted by kengeroothat's what I thought when I opened the package..
Ok, sorry to sound like a idiot but what shaft we talking about?Originally posted by Snake556 View PostCheck your I/C piping, and your turbo exhaust piping. As for shaft play, you can bring it to a specialist shop to have your shafts checked/balanced, but you can also check yourself for visible play by seeing if you can move the shaft up/down/left/right by jiggling it.
Nexsys, your GTR comes up as:Originally posted by Nexsys View PostCan you run mine to? BNR32212739
September '91 (91 09)
GTR Trim
RB26DETT
Color BL0 (Greyish Blue Pearl)
5-Speed Manual Transmission'03 Ford MustangOriginally posted by kengeroothat's what I thought when I opened the package..
