the story goes...
i was driving the other night like any other night, some spirited bursts nothing crazy. then i stop at a light beside my friend and he notices that my engine bay is steaming like crazy out from behind my drivers side front wheel.
quickly i pull off and pop the hood. Other then the loud hissing and puddle that's quickly accumulating beneath my car, we can't see anything because it's dark out and the dinky flashlight i have isn't good enough. Fearing the worst he goes home grabs his trailer and we get it back to my driveway.
Today i started the investigation.
Check Dip stick. everything looks normal filled to right spot, whew!
Check Rad.....Empty
I start to fill the rad with water trying to narrow down the source and it starts pissing out from behind the engine, and i don't mean a slight drip. it's coming out as fast as it's going in. The problem is that it's impossible to see exactly where it's coming out of. There are too many hoses/ everything else blocking the view.
So from what i can tell. It's the back of the engine, above the bell housing, there are 3-4 small lines (oil?) right on top of where it seems to be coming from. I'm starting to think the head gasket but hoping it's not. I was told my engine has a metal head gasket installed. (omori refresh)
Does anyone have and insight to where it may be leaking from, connection loose? bolt popped out? hose burned through? anything other than a bad gasket?
this is a bummer.
Check Rad.....Empty
this is a bummer.
