Help Jun Surge Tank
  • yury_b
    replied
    Thanks alot for you help!
  • malibusst
    replied
    remove studs with either a stud remover or vice grips. then use 8MMX25MM bolts with washers...
  • yury_b
    started a topic Help Jun Surge Tank
    Help Jun Surge Tank
    Hi guys,
    So I ended up having catastrophic engine problems However in the end I ended up picking a brand new NUR SPEC Engine!!!!!!
    I am halfway through putting everythign together and I'm stuck.
    I have just received my new surgetank from JUN and I don't know how to install it. When I mount it up on the studs, the studs are to long and it doesn't even fit.
    Has anyone installed the tank before?
    Any help would be much appreciated.
