Weird Oil leak/drip help....
  • hozer
    replied
    think I got a bad seal somewhere... gonna have a look
  • Bugsly17
    replied
    could be some left over oil from the oil filter(as if makes a huge mess when changing filter)? or if you have a relocation kit, a little drip from that.
  • nismo-152
    replied
    Do you have the breather tube from the diff running up to the air trap under the intake manifold still? It sounds like a small bit of gear oil is being purged from the diff. This is normal.
    Also,are you running a high spec race motor? What are your bearing tolerances? Why the need for 20/50?Sounds quite heavy to me!
  • hozer
    started a topic Weird Oil leak/drip help....
    So I have what I would like to define as an oil leak... Only problem is it doesn't happen all the time, and its only ever like 1 or 2 drips. It isn't constant and there seems to be no reason as to when it occurs.
    The oil "leak" always form right underneath/ around my front diff area under my intake/throttle body area. Im running 20W50 and have high oil pressure when its cold.
    Is it possible that the high oil pressure when its cold could cause a small drip if boosted?
    Reallly confused, gonna hoist it up and check it out later but doubt I will find anything
