Help!
  • fwd suck
    replied
    does any one else know what it could be?
  • fwd suck
    replied
    Originally posted by markc32 View Post
    no boost then u got a leak somewhere also check bovs!
    im running hks ssqv
  • mightyrocker
    replied
    he says he did a boost leak test
  • markc32
    replied
  • mightyrocker
    replied
    Possibly.. keep an eye on your boost gauge under throttle and it will give you a good idea of what they're doing. One may be sticking open.
  • fwd suck
    replied
    yes new filter car ran awesome for 4 months after rebuild
    maybe wastegates?
  • mightyrocker
    replied
    Had this problem a while ago. Caused by a kink in the fuel line and a clogged filter.. But I'm assuming if you did the fuel pump you also did filter?
  • fwd suck
    replied
    Originally posted by amnash View Post
    fuel pump is fried.
    have a fuel pressure gauge?
    Replaced feul pump when i rebuilt the motor!
  • amnash
    replied
    fuel pump is fried.
  • fwd suck
    started a topic Help!
    Help!
    No boost at 4500 sounds like wastegates just open and car bogges
    + there is a lot of turbo shuffle when car is just crusing in low boost.
    I did a boost leak test, cleaned mafs, checked plugs and clened, checked all vac lines, and tested the coilpacks.
    Has ne one had this problem before?
    It just stared happening the last fiew days
    Pls help
    THX
