Throttle Body Shaft Seals
  • dsmart
    started a topic Throttle Body Shaft Seals
    Just putting it out there again to see if anybody has come up with a workable solution to replacing the shaft seals on the RB26DETT throttle bodies. I know there used to be a kit from xspower or something but they are no longer around. I've looked around for another replacement but haven't come up with anything that will properly fit. If anyone has come up with something please post it up. I imagine almost everyone with a GTR is going to experience the need for these at some point.
  • scottiep
    replied
    update on this old old thread lol.. but I found on rhdjapan.com you can buy a throttle seal kit made by reimax. That may be something?
  • doyle4281
    replied
    Were you able to find replacement seals? Did that part number ever produce anything?
  • Godzilla32
    replied
    i did some searching with that part number, pbr is the manufacturer. that part number references to a size 10x18x6. so a regular nitrile oil seal of those dimensions i believe would work. i couldnt cross the number to anything else but those dimensions should definitely aid you.
  • dsmart
    replied
    Update to my last post, I got a call back and the guy found something he thinks matches that number. Ill get them on Monday and report back as to whether or not they are correct. The seals are around $4 each so the price is right...in the name of science.
  • dsmart
    replied
    Found a part number on the seal but nobody ive called can make use of it. Number is "pbr tc12377 10 18 6 1" so if anybody can cross reference that then we might be on to something
  • nickisonfire
    replied
    Nissan just sell the whole assembly i bought it 2 years ago the XSengineering throttle shaft seal for about 100$ if i remember correctly... Like you said i just check and they no longer for sale dont know why they where well made ...
    Nic
  • dsmart
    replied
    Yeah I definitely will be keeping the ITB's its just a matter of fixing the leaks. I have no interest in a big single or buying any new parts, just venting my frustration in how hard it has been trying to located some seals. Its unbelievable that Nissan doesn't have a part number for them.
  • Bruizer
    replied
    I don't know if I'd go to a single TB because of a seal issue (lots of pros to ITB's) but if you're always on the throttle I guess the single is better?
    Bah, go single, will look better with a huge turbo and large plenum!
  • dsmart
    replied
    Originally posted by Bruizer View Post
    Get some made up!
    Probably easier to convert to single throttlebody and new intake manifold than to get customs seals made. Maybe if I commissioned a large run of them and sold them myself it would be worth it but im not interested in doing that.
  • Bruizer
    replied
    Get some made up!
