1/4 mile
    im going out to the local track this friday, i will be running 12-13psi, catback with cat delete, powerflow filter and mines ECU. and im bringing the 16s lol.
    i hope to get a low 14 or high 13, i think im asking to much, but i pull my friends 180 decently with stock boost and he ran a 14.2 so maybe.
      traction plays a way bigger role then i thought, if you can hook up, you might do it, im gonna get some decent tires on the back and i think ill be good for a 14 flat. I never would have guessed i would spin so much into 2nd and one guy told me spinning is the worst thing you can do and eats more time then you would think, i would focus on that primarily, as well as seat time, my first run was a 15.2 and with some practice i almost brought that down a full second.
      Are you in calgary?
      Jesse
      1990 HCR32
      2006 Chev Silverado
        nope i am in medicine hat.
        how is the track up there nowadays, i remember when my dad ran his cuda in calgary you guys had a really good track.
        yeah i didnt think i would spin in 1st 2nd and 3rd. i was told to not just mash the first few gears ( the 60ft will drop but the 1/4mile should pick up) my friend was running 13.9's but had a worse 60ft time than me.
          So, if I ran 15,1 on my stock r33 gts with loaded trunk... It was not bad for the first time?! Next time ill try to use handbrake and will lower PSI in rear tires... Hope it will help...
            Some fill to 26-28psi for rear tyre pressures.
            Also some have dropped 1/4 time by 0.5sec+ with proper darg tyres. ECU retune is known to produce similar results (0.5sec).
            Also raising ride height of car (to stock ride height) to reduce camber problems when rear squats. Another way is to use adjustable rear arms to eliminate the same problem. GTR's can go from low 10sec to high 9sec with this mod. Just cheaper to raise the ride height of car and get an alignment.
            Hand brake technique is similar to a hill start with slowly removing handbrake as you accelerate. Takes some practice to get used to.
            Can practice at light's on hills, flat ground, etc (might wear the handbrake pads inside rear rotors out if you do it too much).
            Setting handbrake is another area that "might" make the technique harder to do.
            The drift dudes loosen the handbrake cable for drifting. Creates a gradual engagement, not sudden engagement. Another way to adjust handbrake is via a round port on rear brake discs / rotors (undo round caps using flat head screw driver on rear rotors / brake discs, poke screw drive into hole and adjust) to get the hand brake handle a little bit higher thus less grip inside rear rotor and more of a slip start. Need to take rear wheels off to adjust handbrake via rotors / brake discs.
              I ran 15.1 last night using hand brake technique and then tried just letting clutch out second run and got 15.2. Tires were spinning worse on second run and I fudged 3rd on first run.
                i ran 14.1 3 weeks ago at cayuga with a slipping clutch and tire weren't hooking up. R/t was .076 so i was alright with that.
                  R33 Gtst Type M
                  - apexi upgraded intake
                  - 3" tuner exhaust
                  - 17" Enkei tuner Rims
                  - tach w/ massive shift light
                  - Running stock boost (2 stage)
                  Ran 14.1 @ 100mph last week
                  2nd time out this is my best time
                  launched around 2800/3000 rpm a little spin but hooked up pretty good
                  Tires: 235/50/17 (rear).......... 215/40/17 (front)
                  Going to work on it this winter to break into that 13 mark i want sooo bad lol
                  Me and my RB .. we tight
                  1994 R33 Skyline gtst
                  2011 Dodge Ram SXT, and yes it has a Hemi!
                  As the late Kernel Sanders would quote:
                  "Im too drunk to taste this chicken!"
                  NismO
                  (Oo_SKYLINE_oO)
                    R32 GTST with rb25 swap
                    Gtr style plenum
                    Q45 throttle body
                    550cc injectors
                    Holset turbo
                    3" Turbo back exhaust
                    20 pounds of boost
                    400 wheel horsepower
                    Ran 12.7 @116mph with a bad launch
                    Need susupension upgrade to stop the wheel hop in first gear off the line. Serious time killer.
                      Gtr style plenum
                      Q45 throttle body
                      550cc injectors
                      Holset turbo
                      20 pounds of boost
                      you must have spun like mad too, maybe im out to lunch but that mph seems high for the time
                      Jesse
                      1990 HCR32
                      2006 Chev Silverado
                        Actually the car hooked well except for first gear. My 60 foot was garbage constantly, i made it up on the top end. I'm putting some sticky 275 rears on and we'll see next year. I was on hard, and shot 255 tires. Talked to a buddy with a mustang that runs about the same 1/4 mile. I mile an hour him but his 60 foot are awesome.
                          So i made it to the track again and step it up.
                          -i swtiched to some 205 55s that actually had thread
                          -shady beaver guys chip
                          -and did a burn out
                          so with these 3 things i managed to step it up to a 60' of 2.25 and 14.1 @102 mph, launch was good but still spun lots in 2nd, i think i need some slicks to get in the 13s
                          Jesse
                          1990 HCR32
                          2006 Chev Silverado
                            I find a burnout doesnt help me much, the track I drag has a nice take off spot, somewhat sticky, plus I dont want to keep replacing my tires >_< ! On sport tires that is
                            NismO
                            (Oo_SKYLINE_oO)
                            • #29
                              Yeah usually i would agree but i have way to many 16s kicking around so i tend to burn them off lots, i heard doing a burnout on street tires is over kill anyways casue they get to hot and lose traction.
                              Jesse
                              1990 HCR32
                              2006 Chev Silverado
                              • #30
                                ^^ no need to do a burn out on street tires, its a waste.
                                R.I.P. Misty Jeanveau 1985-2009. you always will be mine and I will always love you!
