Results 1 to 9 of 9
Thread: Turbo upgrade
    GTRCer Braden @ JNS Imports's Avatar
    Jul 2006
    Lethbridge AB
    5,269
    Turbo upgrade
    hey i have a turbo off a 1999 chevy deisel and im wondering if it will work with the right modifactions and would i if i would gain any hp numbers? It is much larger than stock and the flanges are much larger,
    i dont now if i can use a deisel turbo or not. haha
    PS i didnt buy the turbo its off my dads truck and its not been used:-P
    GTRCer Shadao's Avatar
    Dec 2006
    Kootenays BC Canada
    2,130
    well if you find out the numbers that the turbo would put out and then find a similar turbo thats available aftermarket im sure you would be able to figure out the hp gains if any...
    without knowing the size of the turbo, or how long it takes to spool and how much boost it can make and at what rpm its really hard to say for certain...
    How many kids with A.D.D. does it take to screw in a light bulb?
    Wanna go ride bikes...
    R.I.P \'87 4cyl Rustang
    \'03 Dodge SX2.0
    \'90 GTR32
    Jul 2006
    Lethbridge AB
    5,269
    yah thats what i thought, if i was home i would take some pictures. It is a true Garret turbo and is more than double the size of the stock turbo so im sure there is some decent hp gains. and the same turbo.
    Jul 2006
    Edson, AB
    162
    Don't use a diesel truck turbo on a gasoline car. Those turbos typically have huge A/Rs on the exhaust turbine to prevent heat related damage from hot diesel exhaust. this allows the exhaust to flow freely away fom the engine and take that heat with it. you will most likely have issues with spool-up using one of those turbos. Also, those 6.5 turbodiesels don't use as much boost as you may think, and that turbo is unlikely to perform very well above 15psi because the stock compression on those engines is 20:1. Remember, that turbo was only designed to support 195bhp on an engine that size.
    There are 10 kinds of people in the world: those who understand binary and those who do not.
    Sep 2005
    grande prairie
    464
    I know a guy that tried to run a cummins turbo on his gts.... no gains and ran like crap!
    Apr 2007
    St. Albert, AB
    1,600
    Whoever ran a cummins turbo on a GTS and didn't gain anything is a complete idiot. The cummins sold in dodge light/medium duty trucks use a Holset HX35 turbo, which will support around 600HP. It's similar in size to a GT35R. He should have got a tune and proper supporting mods before you go and spout off about how bad they are, go look on some Honda and DSM boards and see people making 500 WHP on Holsets, then go ahead and tell me they're crap and no better than the junk ass ceramic stock turbo.
    The GM4/GM8 turbos off of a Duramax wouldn't be a great choice, they use a rather small, inefficient compressor wheel and will max out at about 350 horsepower. Who cares if the duramax is 20:1 stock compression, they're a diesel and that really doesn't have anything to do with how much boost they run. Diesels are a totally different animal from gasoline motors, and a turbo that supports 400HP on a diesel can easily support 600 on a gasoline engine.
    :hit_head:
    GTRCer Speeddm's Avatar
    Apr 2007
    Grande Prairie
    690
    I used to sell Cumins turbo cores to guys in California all the time. They work just fine. But you have to know what you are buying. Generally the holsets off the the cummins is a safer bet . I would like to see the specs on the Variable vane unit form the Powerstroke. That is a neet piece of kit.
    Banned
    Aug 2006
    5,913
    if you match the turbo it would be fine.
    reconsidering that diesels typically rev lower you could match up the large a/r.
    matching it to a 2.6L would be not an easy task though.
    but if you dont mind post up some info about it.
    Jul 2006
    Lethbridge AB
    5,269
    will do, when i get home i will take lots of pictures and try to find as much information. Im in vancouver right now so thats a no go:-P
