Does anyone know a dealer in vancouver area that deals with hks or nismo stuff? Cheers
jusr order onlien urself...shops mark them up
MonkeyNutz in burnaby can get you Nismo stuff, as they are a Tomei dealer, and Tomei is the north american distributor for Nismo.
You don't need a car-specific filter. Most are a standard diameter fitment. Find the filter with the largest measurements that will fit into where you intend to put it. And honestly, I don't recommend the HKS shroom filter. K&N or Apexi filters get better numbers, are washable, sound better, filter more effectively, and don't have the possibility of filling your MAFs with foam. BTW, niiiice car!!
Usually the MAF has a little rubber extension hose coming off of it. You clamp the filter on the end of that hose. Do you have nothing after the MAF? Are you currently replacing a stock air box?
