Results 1 to 2 of 2
Thread: Super Hicas light on.
    Banned
    Jun 2011
    Winnipeg
    13
    Thumbs down Super Hicas light on.
    My hicas light is on. would purchasing the Hicas eliminator kit the best way to do it?
    or how much more expensive will it cost to actually fix it without the kit?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,699
    Lockbar works. But for racetrack use a non HICAS subframe to eliminate balljoints and can upgrade subframe bushes at same time. If you search for drift thread's, should find a S13? non HICAS subframe fits (also R32 has a model without HICAS, so can use that subframe).
    If HICAS light on dash is on -
    Low fluid level in powersteering resouvoir (common problem, especially if powersteering hoses in engine bay are leaking due to using factory clamps. Solution is to change to worm drive type clamps and drain, refill with new powersteering fluid)
    Alternator problem (low? voltage)
    Sensor or wiring problem
    Not using a HICAS compatible boss kit (non compatible boss kit interfers with steering angle sensor for HICAS that's behind steering wheel). I think you guys call it a hub?
  1. HICAS and Super HICAS
    By SxyBeast in forum GT-R Tech
    Last Post: 07-07-2008, 01:31 AM
  2. HICAS and Super HICAS
    Last Post: 06-29-2008, 09:15 PM
  3. Replies: 3
    Last Post: 12-14-2006, 08:08 PM
  4. Hicas light on, hicas removal bar in place.
    By Inline Slut in forum GTS Tech
    Last Post: 12-05-2006, 11:19 AM
  5. Super HICAS
    By Super_Steve in forum General Skyline Discussion
    Last Post: 09-07-2004, 12:02 AM
