if anybody have tried fitting . or is it possible
A BIRD ON YOUR HAND ** **** ON YOUR WRIST
no it will not fit.
If you change the rad shroud why wouldn't it? I thought the mounting points were the same minus the shroud. I think if you have the proper shroud it will work if you want one
so the mounting brackets are in the same spot ? top and bottom ? i dont have the shroud anymore . ived got 2 mishi fan fitted on my R33
I have R34 rad that i believe is very close to R33 rad.. let me know if your interested.. **CHEAP**
Yeah R32 and R33 are different at the top for mounting. R33 n R34 have the same. Not sure about shrouds tho
