From technical unbiased opinion. Which is a better Engine RB26 or Surpra's 2jz?
What are the good and the bad in each of these engines?
Also potentially which engine will have the best potential on same amount of budget.
Stock: it's revs vs displacement, like the old saying goes there is no replacement for displacement and it is true. The extra torque however can be countered by not needing to shift for another 1000 rpms, imo I think revs is the way to go, if I wanted torque I'd get muscle not jdm.
Potential: money and creativity is the only limiting factor. 2jz will go further on stock internals but who really gives a f*ck about how far stock can go, if your serious about power/reliability you'd swap them out for forged anyways....
Same budget: depends on the budget.... if you've got the budget to fully rebuild each engines, read ^. If don't have enough money to rebuild then obviously 2jz, they can handle 700rwhp on stock block
Search on google, this topic has been discussed so many times lol. Also it depends on what your using that engine for, different motorsports calls for different applications. For track you obviously don't want a huge laggy turbo since you want a constant, predictable powerband whereas if your dragging the car, it's all about top end...
I feel that I've just regurgitated what is obvious to everyone rofl
my friend put it best and i have to agree. he said that the 2j is the superior motor but the gtr is the superior car. the 2jz is stronger stock and has more readily available parts since it was actually avaible in the north american market. the rb26 has less displacement and of course the oil crank problem but is still a close second. this is all imho of course
2jz; better motor
GTR; better car.
I would suggest 1jz, they can handle a lot of power on stock internals, and they are way cheaper than 2jz!
