Results 1 to 6 of 6
Thread: Battery or alternator?
    GTRCer krystalized_jdm's Avatar
    Feb 2010
    Saskatchewan
    168
    I've been noticing issues lately ever since I accidently left my lights on and completely drained my battery.
    (from what I've told, dry cell batteries are trash after being completely drained and then boosted)
    I'm not 100% sure on battery type. I'll look tomorrow
    Issues I'm seeing now include
    - Stereo, gauges, and turbo timer all reset, or lose power if I hit high-beams, or sometimes when I signal left or right.
    - Hicas light flickers on and off when I brake SOMETIMES
    - Headlights dim when I push breaks (sometimes)
    - Headlights dim when I use power windows
    I'm currently having a misfire issue, but I don't think thats relevant. If it is, I believe it's just a fault coil.
    Any idea whats going on?
    Quote Originally Posted by Robski View Post
    GTRCer Tony-R32's Avatar
    Sep 2010
    Winnipeg
    1,063
    Quote Originally Posted by krystalized_jdm View Post
    It's natural for your headlights to dim slightly when you do this, even on brand new cars. I first noticed this on my moms 08 chevy aveo.
    As well I've noticed that when I hold my window switch down in my skyline after the window has been put down my idle will drop slightly until I let go.
    If you've completely Drained your battery it never hurts to replace it. ecspecially if you've already had it for a while.
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    with dry cell batteries (i have Braille 11,5lbs) the only way the correctly charge them, is to use a trickle charger @ 2amp for a full day
    my battery got drained 2 years ago when the guys at the place where i paid to store my car over winter forgot to unplug the battery,
    it was totally dead,
    now i have to recharge the battery for couple hours at a time @2amp because it won't hold a full charge if i don't drive it for a week
    Feb 2010
    Saskatchewan
    168
    I put a 2v trickle charger on it all day and it stayed at the same amount of voltage
    (according to my turbo timer, its 13.7-13.9 while running)
    Jan 2010
    Manitoba
    216
    13.9 is average alt. output, your battery might be pooched. Have you tried testing it disconnected from the car with a multimeter? Try pulling the bat. and charging out of the car, then test to see if it gets to 12v.
    Quote Originally Posted by Snow View Post
    Sure a condom holds water but you don't see me drinking from one.
    GTRCer Chihuts's Avatar
    Apr 2011
    London, Ontario
    28
    Only reason your lights or anything for that reason should dim or be sluggish is either battery isn't holding capacity, or the alternator isn't charinging enough voltage while running. 2 Simple ways to check which on is the problem:
    1st Test:
    1) Start Car and run at a normal idle.
    2) Connect a Voltmeter Directly Across the battery Terminals.
    3) Turn on Headlights to High Beam.
    4) check the battery Voltage.
    *** The Battery voltage Should read between about 13.8 to 14.2 volts. (Possibly up to 14.5 Volts.)
    Reason for this is because even with a constant drain the alternator should be compensating for the drain on the battery.
    2nd Test:
    1) Connect the voltmeter directly across the "Battery Terminals". (NOT to the Cable Clamps)
    2) While watching the meter, Start the Car.
    3) The Battery Voltage should Never fall below about 10 Volts.
    If it does:
    a) The battery is either "Low in Charge".
    b) Or The battery has a "High Internal Resistance".
    (Possibly Sulfided Plates and probably Time for New Battery?)
    Lastly ... I know its a very simple task but please check the terminals and connecting cable condition, something as simple as cleaning some acid away with baking soda/water can do wonders.
    Hope this helps, keep me updated.
  1. Wtb : Rb20det Alternator/Battery harness
    By lord_shadow_tck in forum Want to Buy
    Last Post: 05-25-2011, 10:30 PM
  2. Car Battery
    By M0nkeyMark in forum Want to Buy
    Last Post: 08-30-2010, 05:52 PM
  3. alternator/battery
    By dips in forum GTS Tech
    Last Post: 05-06-2008, 08:48 PM
  4. Another battery/alternator question.
    By LRM1981 in forum General Skyline Discussion
    Last Post: 04-08-2007, 12:44 AM
  5. Battery?
    By qbopolus in forum GTS Tech
    Last Post: 01-26-2005, 06:44 PM
