Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: tuning round 3 dyno sheet!
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,891
    Bottom end :
    Wesico 86.5mm pistons
    Tomei H beam rods
    acl race bearings
    ati 1000hp damper
    Tomei hi flow oil pump
    Greddy trust sump extension
    Arp Main studs
    Brand New oem nissan r34 crankshaft
    custom crank collar to give .02 clearance on oil pump inner gear
    N1 water pump
    Head:
    Tomei procams 270 duration 10.25mm lift
    Supertech dual valve springs with titanium retainers
    supertech valve guides/seals
    Greddy Timing belt
    Arp Head studs
    tomei 87mm 1.2mm head gasket (and full tomei metal gasket kit)
    Oem nissan gasket kit
    tomei adj cam gears
    5 angle valve grind!
    Turbo Kit:
    Borg Warner S300x 91-79 t4 turbo with a .91ar twin scroll exhaust housing
    Tial 60mm wastegate
    Twin HKS ssqv3 limited black edition bovs
    6boost true t4 twin scroll equal length manifold!
    Fuel:
    tomei 11mm fuel rail
    precision 1000cc injectors
    Custom swirl pot fed by stock gtr fuel pump
    Inline aeromotive a1000 fuel pump
    All stainless steel braided fuel feed and return lines from the pump to the rail
    aeromotive a1000 fuel pressure regulator
    Drive train/suspensionweakest link of build)
    Tranny will remain stock for the time being i am going to pop through alot of them most likely but we will see
    clutch is a os giken twinbdp440
    Zeal coilovers
    nismo tension rods
    ams upper control arms
    larger front and rear sway bars
    nismo engine/tranny mounts
    solid rear subframe bushings
    Cooling:
    Trust 30 row oil cooler with oil filter relocation with all ss braided lines
    koyo aluminum rad
    twin 10" electric fans
    aem water meth kit
    been a project for 11 months now and i finally hopped on the dyno. it was tuned at rg in bc and many of you know the "heart breaker dyno" we were only able to run low boost (12-13 psi) my os giken twin wouldnt hold any more power. so im up grading to a osg r4c or a exeedy triple carbon and going back for ~29psi. anyway here is the dyno sheet.
    Aug 2008
    Edmonton
    347
    Nice man
    Regards,
    Ken.
    Dec 2007
    Quebec
    3,209
    nice built. This winter, I will have to dig in the gtr build section for future idea haha!
    Ovechkin is the best player.
    Dec 2007
    Quebec
    3,209
    one thing tho.. I have a os giken twin plate and it still grab perfectly. No freakin way a twin os giken can't take 313lbs of torque. no need to upgrade to a 4 place and wont be able to drive it in the street, just get a rebuilt kit for your clutch that it.
    Sep 2010
    vancouver
    1,891
    yea it was a used os twin it should hold the power levels but i think its shitting the bed. i do alot of drag racing so a twin at 600awhp wont last long. well neither will my tranny for that matter. but anywho any clutch is streetable with the right driver. ask dragonhumper. im just stoked for 421awhp at 12psi on rgs dyno!
    GTRCer tryingtobebest's Avatar
    May 2007
    Calgary, AB
    296
    Great numbers man, any engine shots? Whats the reve limit?
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    what will it dish out @ 29psi, only gods know !
    Sep 2010
    vancouver
    1,891
    hoping for 600-650awhp at rg at 29psi. and i have a build thread on another forum i might bring it over here ill try and get a few videos up too
    May 2008
    Stouffville, ON
    386
    Good numbers. Your plates are probably just thin is all. You could rebuild it for much cheaper than buyer an R4C.
    Toy - 1995 R33 GTR Vspec - Midnight Purple - trust fmic, 98GTR Xenon's, OSG twindisc, BBS LM champs, and more
    Daily - 2004 Dodge SRT-4 Stage 3R
    GTRCer leeaspin's Avatar
    Nov 2009
    grande prairie
    495
    man our cars can make sweet love together...both pretty much the same amount of power at roughly the same psi! Too bad I need to rebuild now or I would drag you next summer Maybe that will still happen tho!.....What do you have for tires? And what will you be drag racing on?
  1. Sheet, what is wrong here?
    By m_melen in forum GTS Discussion
    Last Post: 07-14-2011, 12:00 AM
  2. Dyno and Tuning Shops
    By got_boost! in forum Western Region
    Last Post: 06-11-2010, 12:27 AM
  3. Ontario GTR dyno tuning
    By Turismo in forum Eastern Region
    Last Post: 03-04-2008, 11:09 PM
  4. Been to the dyno yet? Post your mods,results / dyno sheet!
    By 604CEFIRO in forum General Skyline Discussion
    Last Post: 07-24-2007, 07:11 PM
  5. Dyno tuning?
    By R32GT-R in forum GTS Tech
    Last Post: 10-19-2004, 09:11 AM
