Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: R33 GTR AN0 Super Clear Red Paint Problem
    Oct 2011
    Hamilton, Ontario
    22
    Hi
    I am new to this forum. I just recently imported a AN0 1995 Skyline GTR. When the car was in the dealership in Japan, there was no issue with the paint, however, during transport, areas where the car was covered in blue plastic lead to moisture retention and the paint was burned.
    Picture of the car in Japan:
    Picture of blue plastic areas:
    Car when it arrived in Canada, a lot dirtier
    The car was sitting in the train yard for about 3-4 days in Toronto and there was heavy rain, the car got quite dirty. The blue plastic wasn't applied completely smooth and as result rain water was able to get in. My theory is some sort of solvent or maybe acid rain did the damage. My mechanic tells me its burned all the way into the paint.
    Pictures of Damage to the paint:
    So I am looking for advise as how I can fix this and restore to original condition. Any help would be appreciated. Thanks in advance.
    GTRCer louis110's Avatar
    Jun 2007
    CFB Cold Lake, Toronto
    503
    Wow gorgeous car man! Who did u import it thru? Raw deal with the paint. Try polishing with an orbiter and wax it, see I'd that helps. If not u may need to employ a body shop.
    Jun 2011
    Toronto
    1,562
    Send "CobrAA" a message. Go under media and you'll see some of his detailing work he's done. I'm sure he has a solution for you.
    Or as mentioned above, find a local, reputable body shop.
    Because race car.
    Dec 2007
    Quebec
    3,209
    Quote Originally Posted by MKIV View Post
    thnks for the feedback .
    your in hamilton? that's a 7 hours drive.. since its christmas I have times.. I could take care of it. I will get back to you by pm
    Ovechkin is the best player.
    Dec 2007
    Quebec
    3,209
    my first advice is try to get some kind of polish/compound at Canadian tire like autoglym resin-polish.. rub it with a microfiber... see iif it did something.
    I can't tell from the pic if it's burned or a simple wet-sand will be needed. but I've never heard acid rain burning paint.. Sometime the acid water get etched in the paint but that's only 3-4 microns.. a paint can have as much as 150 microns so 3-4 less wont hurt anything.
    I just dont want to do a 15 hours drive to tell you your paint is burned and I cant do anything for you.
    GTRCer gtrte37's Avatar
    Mar 2011
    Surrey,BC
    100
    sick gtr man, got a mods list and engine bay pics?
    Oct 2011
    Hamilton, Ontario
    22
    Hi CobrAA
    Well when I go over with my hand, the clear coat is clearly still on, as it is on the same level as the good paint. However that is not true with one scratch as I tried using rubbing alcohol and some of the clear came off. How would I be able to find out what the extent of the damage is?
    Thanks
    Dave
    Oct 2011
    Hamilton, Ontario
    22
    Mods list:
    N1 Engine Swapped in
    HKS 2530 Twin Turbo
    After market CPU (Apexi Power FC)
    Power FC Boost Control kit(Apexi)
    FC commander(Apexi)
    660cc injector(SARD)
    cam Shaft (TOMEI PONCAM)
    HKS slide cam pulley
    Turbo outlet pipe(TOMEI)
    Cylinder Head Gasket(TOMEI)
    manifold Gasket(TOMEI)
    stainless exhaust manifold(TOMEI)
    stainless exhaust front pipe(Mine's)
    stainless exhaust center pipe
    stainless exhaust rear pipe
    NISMO Airflow
    Dump valve(HKS)
    Air cleaner(HKS)
    Front mount inter cooler(TRUST)
    After market radiator(BLITZ)
    Fuel pump (NISMO)
    SURGE Tank(NISMO)
    18inc rims(WORK SSR)Front&Rear 235/40/18
    Front K-sport brake Caliper & rotor
    Rear GReddy brake Caliper & rotor
    Coil over Hyper Max III (HKS)
    Twin plate clutch(OS GIKEN)
    Fly wheel (OS GIKEN)
    LSD(OS GIKEN)
    Mine's 320km/h speed meter
    MOMOsteering wheel
    Oil press meter(BLITZ)
    Oil temp meter(BLITZ)
    Turbo timer (Pivot)
    Shift nob(NISMO)
    HID head light
    Jun 2011
    Toronto
    1,562
    Nice engine bay!
    Because race car.
    GTRCer 91hcr32's Avatar
    Mar 2011
    Lower Mainland
    95
    Gorgeous car! Bummer with the paint though. Hopefully it won't cost a lot to fix.
    (o-o) skyline (o-o) == 300zx ==
  1. stuff to clear out
    By ahgil in forum Parts for Sale
    Last Post: 05-08-2008, 01:22 AM
  2. assass1n clear your PM box!
    By Daryl @ RightDrive in forum General Skyline Discussion
    Last Post: 03-03-2008, 10:13 AM
  3. Clear corners?
    By Lancelot in forum GT-R Tech
    Last Post: 08-14-2007, 03:51 PM
  4. Clear Corners
    By Eber in forum Want to Buy
    Last Post: 08-04-2007, 10:47 PM
  5. FS: Clear corner indicators(not completely clear)
    By Rickieroo in forum Parts for Sale
    Last Post: 05-18-2007, 03:03 AM
