Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: LINE-X coat your skyline? now in color
    Banned
    Aug 2010
    UNDER MY CAR, MISSISSAUGA
    291
    http://www.prnewswire.com/news-relea...133889888.html
    i was watching sema on speed and theres a bunch of trucks like the ford raptor covered in line-x rhino liner
    it got me thinking.....
    anyone else got the same idea?
    inside and out rhino lined skyline
    yea or nea
    Banned
    Aug 2010
    291
    The Dominator chase vehicle was coated with LINE-X XS-650, the ultimate weather protective coating. With storms creating winds surpassing 200 mph, the LINE-X XS-650 protective coatings defends against the extreme weather conditions and greatly minimizes dents, scratches and impact damage from high-speed flying debris.
    this is so cool
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    Saw this done and it doesn't look bad and it's super easy to cover up scuffs. I would do it, why not
    Jun 2011
    Toronto
    1,562
    Looks easy but I'll stick to old methods.
    Because race car.
    Banned
    Aug 2010
    291
    old methods?
    vinyl or matte finish? or do you mean scratch compound wax and buff?
    i just think its got an aggressive look
    if anyone is a mythbusters fan ... remember the golf ball dimpled taurus?
    the dimples actually reduced drag
    wonder if it has the same affect with line-x
    not to mention the truck they blew up with rhino liner
    for grocery store lots, rally and track i think this stuff might serve a purpose
    but i mean stripped bottom top inside and out and spray everything
    like mylar wrapper lol
    im going to price it out and see
    im going to have it mostly stripped when brought in so ill hopefully save some $ there
    mythbusters vs line-x
    During the 60 minute episode, LINE-X products were featured in three real-world scenarios, "Bedliner vs. Attack Dog", "Bedliner vs. Car Crash" and "Bedliner vs. Explosion", all suggested by fans of the LINE-X brand on the "MythBusters" website. In the first trial,
    LINE-X was sprayed onto a quilted jacket. After curing, it was then worn in a simulated attack by a professionally trained police dog. The dog instantly attacked the arm of the LINE-X coated jacket; however, his sharp canine teeth were unable to pierce the strong LINE-X Protective Coatings, even with repeated attempts to latch on. The dog then attacked the unprotected leg of the attack suit and was able to quickly pull the "MythBuster" to the ground. With this astonishing result, LINE-X was confirmed to withstand even the most violent and targeted attacks by an animal.
    The second trial was a simulated car accident, and it is important to note that although LINE-X is well-known to protect truck beds from exposure to harsh chemicals, impact and extreme use, it has never been recommended as accident prevention protection. With one half of a crash-test car sprayed with LINE-X from front to back fender, the other half of the car remained unsprayed and unprotected. At low speeds, the LINE-X half of the vehicle did suffer fewer bumps, scratches and dents than the unprotected side. However, at high speeds, both sides of the vehicle were badly damaged in a collision. With these results, this myth was labeled as "busted", yet LINE-X was proven successful in minimizing contact damage and minor abrasions as result of the low speed impact.
    The third and most exciting trial was exposing LINE-X to a controlled C-4 explosion, measuring both the durability of wood and cement block walls when sprayed with LINE-X Protective Coatings. In order to best compare the experiments' results, each blast had a control measure – two identical, yet unprotected wood and cement block walls – in which the LINE-X coated walls were to be compared. Once the dust from the explosions settled, the unprotected wood wall literally crumbed, the LINE-X coated wall stood tall, with only scorch marks to show for the major explosion. In the second set of explosions, the unprotected cement wall also suffered catastrophic damage, and again, the LINE-X coated wall completely withstood impact and suffered only a few spots of discoloration due to the blast.
    With endless applications for automotive, residential, light industrial, commercial and military projects, LINE-X Protective Coatings is the best way to defend against the harshest elements and most extreme environments. "MythBusters" airs on the Discovery Channel network. "Like" LINE-X on Facebook and follow LINE-X on Twitter for more information about unique product applications and other exciting LINE-X news.
    GTRCer gezed's Avatar
    Nov 2010
    Vancouver
    228
    I saw that episode of mythbusters, it was unbelieveable!, but would a coating add considerable amount of weight on the car?
    Banned
    Aug 2010
    291
    i doubt it would be huge difference weight wise but deffinetly heavier then paint lol
    open mouth insert foot
    found this on a truck site
    "I'm a LINE-X dealer.
    LINE-X weighs .7 pounds per square foot at 1/8" thickness. Trucks are sprayed up to 1/4" on the bed and up to 1/8" on the sides."
    so for an 8ft truck bed 50-60 lbs
    i would assume 1/8" or less over interior exterior bottom and engine bay
    could add up to 400lbs ?
    i dunno im guessing
    anyone wanna take a stab at the (interior exterior bottom side and engine bay) surface area?
    and 1/8" seems thick. i mean underside engine bay i could see 1/8
    exterior you could probably go 1/16" on interior/exterior to save weight
    on the plus side its like newer dampening material
    GTRCer Marus92's Avatar
    Jun 2010
    Bathurst NB
    853
    Well there's a reason ferrari uses a razor thin paint coat on their Competizione cars, you can actually see the weave of CF under it. Weight is weight.
    Now I need to see that mythbusters ep!
    Edit: But I'd totally do it on a DD car
    Banned
    Aug 2010
    291
    thanks guys so its not just me.... a line-x coated skyline is a good idea
    Banned
    Aug 2010
    291
    so from what i can find
    Exterior dimensions: (LxWxH): 4545mm x 1755mm x 1340mm
    Interior dimensions: (LxWxH): 1805mm x 1400mm x 1090mm
    Wheelbase: 2615mm
    Ground clearance: 135mm
    so from rough estimates ive concluded
    top and bottom are about 8m sq (16m)
    side are about 5 m sq (10m)
    interior 2.5m just floor so (5m)
    and 4m in engine bay(4m)
    may be 2.5m trunk(2.5m)
    so 37.7 m sq or 116.25 sq ft or about 81 lbs of material
    bu this is rough esitmate
  1. FS: Men's XXL Sean John Winter Coat - Coyote Fur & Down Filled
    By Wrath in forum Off Topic Marketplace
    Last Post: 01-05-2012, 12:06 PM
  2. Replies: 12
    Last Post: 06-25-2011, 12:28 PM
  3. What color sells for the most
    By kelaog in forum General Skyline Discussion
    Last Post: 08-20-2007, 10:43 AM
  4. what color should i paint my car
    By Braden @ JNS Imports in forum General Skyline Discussion
    Last Post: 03-02-2007, 02:59 PM
  5. Paint color codes for R34 skyline
    By Braden @ JNS Imports in forum GTS Tech
    Last Post: 08-02-2006, 03:49 PM
