If you think it's your starter just bump start it. Toss her in 3rd gear get a couple people to push and give'r. If its the starter it should fire right up.
Not to hijack, but I'm in a similar boat. My Skyline has been in storage for the winter (non-heated garage, under a tarp, hooked up to a trickle charger) but I had to take it out a couple of weeks ago because I sold my beater. It started up perfectly, then this -40 weather hit for a solid week. The weather has warmed up (-10ish) for the last few days but now the GTR won't start. The engine will crank over and almost sounds like it's going to start, but just fails. I bought a space heater for the garage but it's useless. Any suggestions to get the thing running?
bump.
still no start. car has been in a heated garage for 2 weeks, new battery, new terminals, new fuel filter, spark plugs have 10K on them and look good when inspected, 1 yr old yellow jackets, changed the CAS, still nothing. Checked blinking light on ECU, shows normal. It just sputters and doesn't start.
I tested the resistance on the ignitor module (i.e. transistor unit) and it was not meeting the service manual specs so it leads me to believe it may be this. But when i took the spark plug out to test it, it was sparking. HELP!!!!
Check your engine grounds?
Connection at your starter/ alt?
Sent from my BlackBerry 9700 using Tapatalk
92 Gtst/Silver bullet
yes make shure all your grounds are good as me and supraclean just went through this with my gtst
TO GRIP OR NOT TO GRIP.... THAT IS THE QUESTION
Where/how many grounding points are there? There's one on the ignitor, two on my battery (one for HIDS)...where else?
