ok where would i find the ground for it
check your connections to your starter...and check your grounds, on my gts-t the only ground is going from the body to the batter and from the block to the same place the battery is grounded
1991 skyline GTS-T - first import/winter project
thanks guys i think we figured it out my battery cables were like cut to the terminals were getting new ones tomorrow n see bcuz we moved the cables from a little bit n then it started fine after so well try it again tomorrow n see.
thanks guys it was my battery terminals its all up n running.
