Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: KNOCK SENSOR fault code , what can it bee need help asaaaap please
    May 2012
    Gfw
    40
    I have a 94 r33 gtst type m just got it dont know anything about it and i looked up how to run the fault codes, the car is loosing boost and power after 5grand dont know what to do ,read the fault codes and it cAme up 34 knock sensor and i thought it was because the intake had come off previously but we put it back on and reset the code and this still comes up i am burning 91 octane what else could this be and how do i check it be descriptive thankssss!!!
    GTRCer Sri-LanKING's Avatar
    May 2011
    Ottawa ON
    153
    maybe like this I'm not sure...
    Error Code 34 - Knock Sensor
    May 2012
    Gfw
    40
    I know what it is i need to know what could be triggering the knock sensor and causing my power loss
    Voodoo_ChildR32's Avatar
    Nov 2006
    Edmonton, Alberta
    1,315
    What's your plugs gapped at? If 1.1 you need to regap to 0.8. Have you tested coil packs as well? If not start there and work your way up till u find it.
    Oh yea, do some reading. These cars are not for noobs. Try googling the issues and you should find tons of info.
    Knock sensors are essentially microphones, any type of detonation will set them off. Spark, fuel, and air are the only things to worry about, make sure all three are good.
    1989 R32 Skyline GTR SOLD!!!!
    -Bruce Lee
    May 2012
    Gfw
    40
    How do i check the coil pack where are they located
    Nov 2006
    Edmonton, Alberta
    1,315
    Coil packs are between the valve covers, just remove the center cover and they are underneath. Most cases you use a multi meter to test resistance in the coil. You will need to remove them to test. I forget which pins, there are three, you are basically looking for less than 0.9 ohms. Any higher and the coil is dying. It is also a good opportunity to check your plugs as well. Also take a look at the wiring harness that connects the coils, I have had issues there before. Check the tech sections on the forum here, there are some good "how to's" for figuring out most of the issue you have.
    -Bruce Lee
    May 2012
    Gfw
    40
    Think it could be the 91 supreme gas thats in her do these cars need a higher octane to run peak?
    Nov 2006
    Edmonton, Alberta
    1,315
    I've run with 91 and 94 and notice no difference except in my wallet. I've even had to run 89 when primo was sold out and been fine. Unless you're leaning out at higher boost, I wouldn't worry too much about fuel.
    -Bruce Lee
    GTRCer DougTaylor's Avatar
    Sep 2008
    Calgary, AB
    217
    My car was tuned for the high octane fuel in Japan when I got it - ran like s*&t. Had to be retuned for our octane. Could that cause the knock sensor to fault?
    May 2012
    Gfw
    40
    Went and put "91" octane gas same as i had and wapped the lucas octane boost to her and she back runs like a top, halifax vs newfoundland gas fuckin crap!!
  1. Error Code 34 - Knock Sensor
    By BongRips in forum GTS Tech
    Last Post: 07-14-2011, 10:22 PM
  2. ECU Fault Code Help
    By Bmeiers in forum GTS Discussion
    Last Post: 06-04-2011, 02:38 PM
  3. WTB: RB knock sensor
    By RR32GTRR in forum Want to Buy
    Last Post: 04-12-2011, 11:01 AM
  4. Knock sensor wiring
    By kelaog in forum GT-R Tech
    Last Post: 07-22-2008, 08:41 PM
  5. What is Fault Code 54?
    By judasentinel in forum GTS Tech
    Last Post: 08-03-2007, 10:01 PM
