Results 1 to 9 of 9
Thread: PREDETNATION
    Oct 2009
    Saint John NB
    601
    PREDETNATION
    What are some reasons for this? aparently my engine has done it before... samy cylender as well... any help?
    1989 Gts-T Sold
    1992 Gt-R Sold
    1991 Gts-T Sold
    1989 Gts-T~True love
    GTRCer Kras's Avatar
    Dec 2007
    Calgary, AB
    546
    how do you know your engine is det
    1991 Black GTR
    Oct 2009
    Saint John NB
    601
    0 compression in one cylender, the spark plug broke off the tip in the cylender, any other ideas? havnt got the head off yet
    1989 Gts-T Sold
    1992 Gt-R Sold
    1991 Gts-T Sold
    Dec 2007
    Calgary, AB
    546
    If you have 0 compression your piston/piston rings are probably damaged, time for a rebuild
    1991 Black GTR
    GTRCer bobbo's Avatar
    Aug 2009
    Halifax Nova Scotia
    1,500
    That would be the result of A LOT of detonation. Which cylinder let go?
    There are so many things that can cause it. Timing being to advanced, hot spots in the cylinders caused by carbon deposits, wrong fuel and maybe wrong plugs.
    If your cylinder let go that bad I would suspect a couple of things: Excess boost and inusufficient fuel, or even just lack of fuel.
    It might be easier to come up with a hypothisis once you get it all apart... it'll make for some cool pics too!
    Good luck! $$$$
    btw I know some REALLY good engine guys in Saint John that maybe able to help you out. PM me if you're interested
    Oct 2009
    Saint John NB
    601
    you have a pm, also the cylender didnt go, we think its head damage
    1989 Gts-T Sold
    1992 Gt-R Sold
    1991 Gts-T Sold
    Gregzilla's Avatar
    Aug 2006
    Eadmawntonne
    693
    with zero compression i'd be suspecting a busted valve wich could be bouncing around the cylinder breaking off your spark plug tips. If you have access to a boroscope i'd look down the cylinder with that. either way, it sounds like at the very least the head needs to be removed and reworked.
    GTRCer Skym's Avatar
    Sep 2007
    South
    7,968
    Ouch. Check injector on that cylinder.
    Jul 2008
    Alberta
    1,798
    the spark tip could have jammed the valve and bent, your lucky if thats all that happened, being the rb26 is an interfereance motor.
