Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: timing belt whine...
    May 2008
    united states
    72
    So I get my r32 gtr up and running and I hear a faint supercharger whine noise coming from the front of the engine, after narrowing it down I find its the sound of the timing belt. I have replaced everything on his motor, it is fresh with all new oil pump,timing belt,tensioner,spring,idler pulley,idler bolt. My question is we have went through a couple of times and cant totally eliminate the sound, I have set it a few different ways. 1 being extremely tight which caused the noise to be loud, now I have made it a little quieter but it is still there. I searched around and found that some people say it tends to be common with kevlar belts (I have a Power Eneterprise kevlar belt) also some people say it is also common with cam gears that are worn (I have a set of older Tomei cam gears). Lastly I have read that the belts tend to quiet down after you get some miles on it. Can some one put me to ease with similar situations?
    GTRCer ck_chino's Avatar
    Mar 2009
    Toronto
    176
    when i first did my belt i heard the same whining, however mine went away after some driving. not sure about kevlar i used an oem belt
    GTRCer benelli's Avatar
    Apr 2009
    Richmond
    60
    is the noise very loud (like a screeching sound) and constant?? In my car i had a loud whine every time i would start the car...i later found out it was my alternator belt...i made it tighter and the noise was gone. IF not then...no idea could be kevlar belt.
    May 2008
    united states
    72
    is not a drive belt they are off, I eliminated that problem, its mor elike a faint supercharger sound. The motor has been together for a few months now and Ithe car has been a huge restoration and mod ordeal and is my first rb series car. I am hoping once on the road it goeas away after some time for it to wear in.
    GTRCer Nismo_line's Avatar
    Nov 2009
    204
    1,380
    i think it just needs to wear in a but drive it for a bit if it still makes that noise then go mad and try to find the problem
    Your greatest opponent isnt the car next to you but the ground beneath you
    Check out my build in the 204 http://forums.gtrcanada.com/gts-project-cars/46957-skyline-build-204-a.html
    GTRCer Zacho's Avatar
    Jul 2008
    Edmonton
    509
    My timing belt whined (rpm dependent) when it was too tight.
    RB25 Sedan - 460whp@19.8psi
    http://www.youtube.com/watch?v=EdlzkxypdxU
    GTRCer Speeddm's Avatar
    Apr 2007
    Grande Prairie
    678
    Belt is to tight.
    May 2008
    united states
    72
    so how loose does it need to be then? it basically has no tention on it now, just enough to be able to twist the belt a quarter-half twist... The tensioner is set at about 5:30
    got_boost!'s Avatar
    Jul 2004
    Places people shouldn't live.
    1,426
    You should be able to move that belt half an inch to an inch up and down between the cam gears.
    -Josh
    1991 Mitsubishi Eclipse GSX
    1990 Skyline GTS-R
    May 2008
    united states
    72
    you mean between the cam gears up top I should be able to twist it a half inch or physically pull it up a half inch?
  1. where; timing belt
    By gts-ter in forum Eastern Region
    Last Post: 05-21-2008, 01:25 PM
  2. Timing Belt
    By BK_GT1 in forum GTS Tech
    Last Post: 04-05-2008, 11:45 PM
  3. wtb--> Timing Belt!
    By cdnGTR in forum Parts for Sale
    Last Post: 11-24-2006, 12:25 AM
  4. WTB: timing belt
    By GT-Rob in forum Parts for Sale
    Last Post: 04-08-2006, 01:30 PM
  5. Timing belt how to
    By got_boost! in forum GTS Tech
    Last Post: 12-03-2004, 07:22 PM
