Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: R32 GT-R HICAS light on, only after 30+km on highway?
    Feb 2010
    Ontario
    105
    Have a weird one here; on the way to the track (Calabogie), the HICAS light came on after about 35km of steady-state highway driving.
    When the car was restarted for track sessions the light was out, and after five lapping sessions (about 75km in total) the light never came on.
    On the way home, again after about 30+ km the light came back on!
    Any ideas what would trigger the HICAS light on long(er) trips?
    Addendum: I do have an aftermarket "rev-meter", whose primary purpose is to get around the 180km/hr limiter. I did move the cables around a bit for it before the trackday, so maybe I don't have a good connection for the ECU speed sensor circuit. (the device is spliced into the ECU speed sensor circuit so it can "fake" speeds above 180...)
    GTRCer Spencer87's Avatar
    Apr 2010
    Richmond Hill
    265
    I had mine only come on after 10-15km of hwy driving (hovering around 120km/h). At the time, I thought it was because of my aftermarket steering wheel (apparently theres a controller that you need to get or something), but nothing changed and it stopped about two months ago
    93 R33 GTST - Summer Daily Driver
    2000 Buick LeSabre -RIP
    Feb 2010
    Ontario
    105
    With respect to the error reporting, is it the last fault recorded, or does the system need to be currently faulty to report a code? (light on)
    Also, if the light is off while driving, does that imply that all is (currently) well with the HICAS system?
    Hmmm....
    Apr 2010
    Richmond Hill
    265
    I cant remember the details, but I remember reading something here or on Wiki.
    http://www.skyline-owners-club.com/f...yline_book.pdf (our link died for some reason and the thread is closed).
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    mine does this as well. I thought it was because my alignment was off.
    GTRCer NeptuneGTR's Avatar
    Jun 2009
    Winnipeg
    521
    Isnt it that the ecu sences that its highway driving, im perrty sure its just goes it to highway mode, Its normal.
    GTRCer Nismo_line's Avatar
    Nov 2009
    204
    1,501
    mine does that some times too but i have no hicas pump
    Jun 2009
    Winnipeg
    521
    The first time it happend to me I freaked out, i though something was really wrong.
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    Quote Originally Posted by NeptuneGTR View Post
    Huh? I don't think there's such a thing as "highway mode"...lol
    If the light is on, then something is wrong. The ECU should throw you a code.
    And bubba, I think the light as to be on for the ECU to throw you a code, meaning you have to check it when the fault happens. (but don't quote me on this, I've never tried it, just something I vaguely remember reading).
    If you're HICAS system is locked/not entirely there (like foxracing), then its normal that the ECU throws you an error after a while. I have a lock bar and I get a code after a few kms of highway driving because whoever locked it did not bypass the light/cut the wire, and I'm too lazy to do it (the light doesn't bother me that much).
    Since HICAS only activates at 80+ km/h, if you're only city driving you would not notice an issue. That's why the error happens after a couple kms of highway driving.
    Feb 2010
    Ontario
    105
    Quote Originally Posted by DarkCaporaL View Post
    ...Since HICAS only activates at 80+ km/h, if you're only city driving you would not notice an issue. That's why the error happens after a couple kms of highway driving.
    That really doesn't explain why there was no HICAS fault light in a series of 15+ minutes track sessions after arriving at the track! FYI, a 5-lap session at Calabogie is almost 30km, and about 15 minutes at a "casual" pace. I'm pretty sure my first session was about 7 laps, or about 40km.
    Either the HICAS ECU does a system poll after a significant delay, or there's something else at play here with respect to high(er) speed steady-state driving and the HICAS ECU fault checking routines. (it seems that others have experienced the light only after a duration of highway driving as well...)
    FYI, in my case in both directions (to/from the track), the delay 'till the light came on was about 20 minutes.
    I'm also assuming that if the system was really borked, it should throw the code the first time it tries to activate. (ie, the second corner at Calabogie!)
    Hmmmmm...
  1. HICAS light is on...?
    By NaraShikamaru in forum GT-R Tech
    Last Post: 01-11-2008, 07:37 PM
  2. Replies: 3
    Last Post: 12-14-2006, 08:08 PM
  3. Hicas light on, hicas removal bar in place.
    By Inline Slut in forum GTS Tech
    Last Post: 12-05-2006, 11:19 AM
  4. Hicas light on... Uh oh!!!
    By jonesy in forum GTS Tech
    Last Post: 12-17-2005, 01:49 AM
  5. HICAS light comes on
    By JZ in forum GT-R Tech
    Last Post: 05-28-2005, 03:36 PM
