Alright i've received my solid subframe bushings and diff bushings,now I have two questions:
Q #1 .I think I have the answer to this one but im just making sure .In the picture bellow ,the solid bushing with the flat top should be mounted facing up towards the body and not on the lower portion of the subframe facing the ground right?
Q #2.Diff bushes ,as you can see one bushing is thicker than the other .Would it mount or the top portion facing the underbody or lower portion facing the ground?Also you can see the bushings are to tall and the brace is not up tight with the subframe , should I shave down the bushing or add a washer where the gap is?
Thank you
LinkBack URL
About LinkBacks
