Results 1 to 5 of 5
Thread: Ignition problem? (battery light on)
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Just a weird problem that occurred spontaneously last night on a cold start.
    The battery light doesn't go off after the engine starts.
    Typically the battery light stays during ignition the turns off when the engine runs.
    Car functions same as before, other than this battery light staying on. A few of my gauges are blinking like it's in ignition too. (I have started taking it all apart to see if there was a short somewhere)
    Any ideas?
    cheers
    GTRCer Bruizer's Avatar
    Oct 2006
    1,504
    Hmm. well, my alternator crapped out once. Started beating on the battery cause it wasn't fully charging anymore. Same symptoms but lasted a few months before it fried and didn't charge at all. Could be a bad connection to the battery or to the alternator, both easy to diagnose.
    No build thread.
    1991 nissan
    El terror
    GTRCer Zacho's Avatar
    Jul 2008
    Edmonton
    533
    The battery light will usually come on when the alternator is not charging sufficiently, or erratically.
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    Yup alternator issue somewhere.
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Update:
    Car ran on battery power for 2 days with bad misfire and eventually bit the dust. LOL, it just had to die when I needed the car the most. Towing was a good coin spillage.
    Took the alternator out, dropped off at a renowned rebuilder in town.
    Rebuilder says its coils are burned out, getting it rebuilt = ~ $140 bux and guaranteed.
  1. Battery\Voltage Light
    By sexonwheels in forum GTS Tech
    Last Post: 02-12-2008, 12:10 AM
  2. Head light problem
    By RHMadness in forum GTS Tech
    Last Post: 07-08-2007, 11:30 PM
  3. 4wd light problem!?! NEW INFO!!!!
    By cdnGTR in forum GT-R Tech
    Last Post: 12-10-2006, 09:47 PM
  4. light problem
    By nismo56 in forum General Skyline Discussion
    Last Post: 11-08-2006, 06:53 PM
  5. Head light problem!
    By qbopolus in forum Legalese
    Last Post: 03-02-2006, 07:33 PM
