Don't use carb cleaner or brake cleaner. It can damage the MAF sensor.
Use CRC MAF cleaner (link below explains why you don't use carb cleaner) -
http://www.youtube.com/watch?v=vPT8rL0noYg
Or at least use electrical contact cleaner.
With battery, resetting ECU, only need to remove negative cable. But if want to be 100% sure, pull both cables in correct order and stomp on brakes to remove any left over charge.
Oil in rubber intake pipe infront of turbo is normal. It's blowby gas + oil being ejected from exhaust camcover via rubber hose of camcover breather, hardpipe that connects to rubber intake pipe infront of turbo when engine is under boost and at higher rpm. If you want to stop this from happening, fit a oil catchtank.
BOV releasing to atmosphere can make engine run rich after it goes off, best to recirculate when engine has MAF. With aftermarket ECU + MAP sensor, etc, can run it either way.
I would think MAF is making ECU hit boost cut (used when turbo overboost's). Airleak between airfilter, MAF can make this happen, especially if airfilter clamps onto MAF adaptor that bolts onto MAF. Bolt on airfilter (dry type airfilter that has no oil, like Apexi, etc) is usually best to avoid this problem. Or faulty MAF due to using carb cleaner might make it do it.
Rough idle could be due to airleak in rubber intake pipe infront of turbo or airleaks in intake piping. But it's normal for idle to be a little bit rough due to stock o2 sensor. Especially when engine has mods and is untuned or there's a airleak. A long trip on motorway helps to clean sparkplugs, etc and idle is usually smooth afterwards.
Sometimes the airleak can be the gasket under BOV, as it's a use once only type of gasket.
