Results 1 to 7 of 7
Thread: stalling problem
    GTRCer gtstevan's Avatar
    Oct 2010
    Miramichi New brunswick
    92
    stalling problem
    just wondering if anyone else has had this problem
    so i have noticed that when car gets down to half a tank of gas when i swing the car around or do donuts after going so far around the car will stall and doesnt want to start again for a minute or 2 but then sxtarts up and works perfect again....last night i went out to try it jsut to see and i noticed if i start from a dead stop to do a donut that i did over rev it in first gear and at 7500 rpm the car shut off...and it seems like everytime i have done this it has bin at a quarter tank of gas when i first started playing with this i had half a tank of gas and no problem.....car is a 91 gts-t with rb20det
    any help is greatly apreciated
    1991 skyline GTS-T - first import/winter project
    GTRCer surfer's Avatar
    Apr 2011
    Land of the living sky
    30
    Your car hates you, for being a show off doing donuts...and u want us to help you so u can do more donuts?......heres an idea sell ur car and just get a civic.
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,700
    As long as he's doing it legally (skid pad).
    Probably fuel starvation and is common on hard driven cars with low fueltank where fuel moves to one side of fueltank and fuelpump gets starved of fuel. A collector tank / surge tank in trunk fixes that problem or keep fuel tank full.
    Also note you will get a fuel smell in car unless you run a teflon lined braided hose to and from collector tank.
    Sard sell a bolt in collector tank, where the fuelpump that draws fuel from collector tank and sends to engine is mounted inside collector tank (quieter) than using external fuelpump (louder) -
    http://www.sardracing.com/products/f...lectortank.htm
    Example of a external fuelpump sound on a R33 GTR -
    http://www.youtube.com/watch?v=SIFNA7_2mGU
    Alot cleaner to run fuelpump inside collector tank and fuelpump shoud run cooler inside a collector tank. Also takes up less room inside trunk.
    One of the sponsors should be able to sell you a collector tank to suit your application -
    http://forums.gtrcanada.com/sponsor-forums/
    GTRCer gtrjerry73's Avatar
    Apr 2011
    spruce grove alberta
    246
    ya sounds like fuel pumps runnin dry this is bad stop doing it not good for pump and you will run very lean even for a half second can do some damage.
    Oct 2010
    92
    thanks for the reply...and surfer...maybe befor being a smartass you ask where this is being done...in my town i am from we have local burnoput contests put on by the local demolition track...so yes it is being done legaly.and by the way i had a civic i traded it for my skyline straight trade
    Oct 2010
    92
    skym and gtrjerry73 thanks for the replyu it was helpful
    Jun 2010
    Ottawa
    368
    Happened to me at iCar on my first drift night. I kept spinning on one corner and sometimes it would take a while for the car to start. The options the other guys mentioned seem to do the trick. I would jsut make sure you go to the track with a full tank of gas, thats all.
  1. Problem: stalling, now with afr values.
    By gregrego in forum GTS Tech
    Last Post: 07-19-2008, 01:12 AM
  2. Stalling when I let go of gas - BOV or AACV?
    By judasentinel in forum GTS Tech
    Last Post: 06-18-2008, 07:06 PM
  3. Stalling/rev problem?
    By deliberate32 in forum GTS Tech
    Last Post: 03-11-2008, 04:46 PM
  4. Engine Problem (stalling)
    By Jax in forum GT-R Tech
    Last Post: 06-24-2007, 12:32 PM
  5. occasional stalling problem
    By justincredible in forum GT-R Tech
    Last Post: 08-01-2006, 08:17 AM
