Im going to guess series 1 because of the obvious bolts in where the ignitor should be but would like confirmation please
thanks
Kyle
thanks
Kyle
Originally Posted by funkymonkey
I have personally never seen a series one next to a Swiss two but I don't imagine you could tell just by that. Shouldn't there be a code on the back of the engine.
Go to the second picture on the bottom right of your engine there should be a code that says rb25, and should be followed by a few numbers or letters. I imagine that would be your reference point. I remember seeing this when I had my engine out
do you have the turbo that came with it? if so, what are the brandings on the compressor housing?
A. Nash
i had already posted that number in a seperate thread trying to find out that info that way with no luck
need a nissan fast refrence for possible purchase
Kyle
ah i dunno then. maybe ask seller if he has the turbo just for reference..see if he can sell u a pic.
A. Nash
no he got the motor in a trade from another person who he doesnt know that kept that turbo. all i have access to is what i have here, which makes it hard. i guess ill just have to pick it up and go from there..
Its really seems like a waste to even put an engine code on the block if there is no way to look it up and get the purtinent info..
Kyle
Do you happen to have a part number on the coil packs in it? The ones in the series 2 come with ignition directly built into the coilpack and are a completely different number. From the looks of it I would say these should match up with a rb20 coil pack. Try that one man. In the mean time I will keep thinking.....
i will ask for a picture of the coilpacks. thanks
Kyle its an S1 motor.
