Results 1 to 4 of 4
Thread: is this overkill ??? - 4-Channel Wideband UEGO Controller
    kengeroo's Avatar
    Apr 2010
    vancouver
    588
    GTRCer drew6's Avatar
    Oct 2010
    Moncton
    66
    Overkill for what purpose?
    The ability to monitor each cylinders AFR is certainly much more beneficial than just having the average AFR from all 6 cyl. However, is it needed? No. Is it ever to be needed? Probably not. A cheaper option is to have 6 EGT probes. If all cylinders are getting the same fuel/air/spark then the EGTs should be very close. If any of them are cooler or hotter than you know you are not getting the desired AFR in that cylinder.
    GTRCer clone's Avatar
    Aug 2010
    Caledon
    225
    I guess you probably need two, because I think you would need 6 channels. looks cool...probably overkill
    I am using a Digital Wideband Air / Fuel Gauge
    and pretty happy with it.
    kengeroo's Avatar
    Apr 2010
    vancouver
    588
    my thought was people with an A/M EMS, you're able to control injector % per cylinder...
    I have googled that peeps measure temp of each output on the exhaust side and bump up inj % on high temp cylinders...
  1. Arm uego wideband
    By cschepp in forum Sponsor Forums
    Last Post: 11-26-2010, 10:03 PM
  2. fs aem uego
    By farmer in forum Parts for Sale
    Last Post: 08-03-2010, 05:04 PM
  3. Fitting an AEM Wideband UEGO
    By judasentinel in forum GTS Tech
    Last Post: 10-15-2007, 08:21 AM
  4. looking for a 5 or 6 channel amp
    By assass1n in forum Parts for Sale
    Last Post: 12-28-2006, 04:22 PM
  5. VDS on Discovery Channel
    By jymz in forum General Skyline Discussion
    Last Post: 11-09-2005, 10:58 AM
