I had a shop install the splitfire ignition coils,and #7plugs. they have never done it before.
they just swapped them in.
RB20det
I thought something is suppose to be removed?
RB20det
Im almost 100% sure that they just swap in. Are you having problems after install?
In your pic, the circuit on the left is Old school, with a ignition coil and distributor. The circuit on the right is essentially what an RB runs, but we use a Exhaust Cam Sensor and ignition module instead of a Old School distributor.
they are 100% drop in as beacher1b0 stated, our cars use coil packs no distributor dont worry all should be well:P
Thanks man, I was worried.. everything is running good..
guess that diagram is for another model
You would have known pretty fast ifthey weren't installed right. Anyway, td not a big deal if a shop hadn't done it before. It's just a car like most others, by a space ship haha.
No build thread.
1991 nissan
El terror
