Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Rb20det running lean and throwing egt/cat sensor code. Help
    GTRCer redrocket's Avatar
    Jun 2010
    calgary
    51
    hello, so i recently installed an AEM UEGO sensor *following instructions* on my RB20. i took it for a rip after it was good and warm and it seems to be leaning out to around 15.5 and upwards to where at full boost it just shows bars (unreadable). at the same time my EGT/catalytic converter sensor light shows up. i want to be running rich but it seems as if i am leaning out. below are the mods i have and what i am running currently, (i just pulled the car out of hibernation)
    RB20DET
    FMIC
    NGK iridium heat range 6 ***NEW***
    divorced wastegate pipe
    3"downpipe
    3" testpipe (EGT sensor is hose clamped to the top of it as there is no bung, as people recommend when not using a cat)
    3"exhaust
    HKS intake
    HKS atmospheric SSQV
    new oil
    new fuel filter
    LUCAS FUEL TREATMENT (as it has been sitting all winter)
    HUSKY 94 octane fuel
    now what i need help with is shutting that code off whether it be looping the wire or just cutting the wires at the sensor and seperating them. does that code being thrown cause the ecu to run less fuel? Do i just need to break in the plugs? the sensor throws the code as soon as i start the engine and it WILL NOT go out. is there anything i can do to run more rich. i know its less efficient but it is a daily and i want it reliable...plus i am the "**** disturber" with my loud car on my quiet street...i might as well give the neighbors a fire show too. THANK YOU AND YOUR HELP IS GRRRRREAATLY APPRECIATED
    Jun 2010
    calgary
    51
    p.s. does that sensor put the car into limp mode when its on? i drove it and it still pulls hard. im just wondering if it would lean out the mixture. i think if anything the ecu would put more fuel in it........
    FWD = Fukin Wont Drift
    May 2008
    Fort Erie
    764
    Find yourself the R32 Engine Service Manual and R32 GTR service manual. It will help u to diagnose problems in the future.
    What CODE # is the ECU throwin?
    Not sure if the Cat temp light would throw it in to limp mode, it would make sense if it did.
    With ignition ON the cat temp sensor light should be OFF. With ignition in Start it should be ON, then turn off when car starts.
    Unplug Cat Temp Sensor harness from module under Passenger Seat. Looking at the HARNESS PLUG( not module) head on, the locking tab should be at the top. Ground the bottom right terminal, Turn Ignition ON, The light should go out. If light is OFF, it was the sensor that was throwing the code. Also im sure you could just permanently ground the Terminal on the Harness Plug.
    If the light is ON you have a problem else where(harness etc).
    Also, make sure your UEGO gauge has a great clean ground. I would not b pushing your car with AFRs that LEAN, you will go bOOm soon.
    GTRCer vincegts's Avatar
    May 2009
    king city
    53
    i have the same problem ? i changede the fuel filter and it got alot better
    May 2009
    king city
    53
    my hot cat light is on how can i get codes from it ? it flashs
    Jun 2010
    calgary
    51
    Never thought of the ground. Its on the hoodrelease boltunder my dash. Ill try
    Jun 2010
    calgary
    51
    Quote Originally Posted by vincegts View Post
    If you have a pfc yourr detonating
    Jun 2010
    calgary
    51
    Update. Ex leak 10" past uego. No intake leaks. Coing to 7 plugs and swapping ecu
    Jun 2010
    calgary
    51
    For the blitz tuned access ecu. Should help as the fuel map is different?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,700
    That cat sensor light can come on for a few reasons -
    Cat sensor is not earthed to exhaust or exhaust temps are past 800? degrees C (I think when it activates the light).
    ECU is in diagnostic mode, not run mode (screw on side of ECU)
    Both of which I've experienced on my car (not the temp part). The cat light would light up when hitting bump in the road (due to screw not being fully in run mode on side of ECU).
    Basically cat light is a engine check light as well as exhaust temp overheat light. Other light's on dash are similar, like handbrake light is a low fluid level in brake master cylinder resouvoir light (due to leak) and telling you handbrake is engaged.
  1. running EXTREMELY LEAN at idle
    By RWD_GTR in forum GT-R Tech
    Last Post: 10-07-2011, 06:56 AM
  2. Signs of running lean vs. running rich
    By judasentinel in forum GTS Tech
    Last Post: 05-07-2011, 09:03 PM
  3. running lean on a stock ECU
    By linedriver in forum GTS Tech
    Last Post: 10-27-2007, 11:34 PM
  4. rough idle (running lean)
    By MikeyRHD in forum GT-R Tech
    Last Post: 10-04-2007, 01:59 PM
  5. Hicas code 9 (neutral sensor)
    By GTS-4Skyline in forum GT-R Tech
    Last Post: 07-26-2007, 09:51 PM
