Results 1 to 3 of 3
Thread: wheel allignment
    GTRCer evolution23's Avatar
    Mar 2011
    Surrey
    227
    wheel allignment
    So today i lowered the car a bit with adjustable coilovers and just noticed that my right front tire is sitting closer to the back of the wheel well. all other tires are good but just the right front is not centered. Do i just need the caster adjusted or could i be in need of a lower control arm? Whats the usual cause of this and what are ways of checking to see what it is that i need. thanks!
    GTRCer Tony-R32's Avatar
    Sep 2010
    Winnipeg
    1,063
    when i hit a curb and took it to an alignment shop they told me the only thing wrong was damaged tension rods, the oem bushings aren't very good. replaced with with KTS adjustable tension rods (which allow you to adjust castor) and that brought my wheel back to the center of the well.
    So before you go replacing the whole lower control arm, check the bushings on your tension rods, if they are really cracked and leaking replace those. even if they aren't damaged replacing them gives you the ability to adjust.
    Mar 2011
    Surrey
    227
    i already put adjustable tensioning rods in. So im guessing the shop just didnt align them right? I am going back to the shop that did the allignment and seeing if thats all it is.
  1. clutch allignment tool
    By shawnr204 in forum GT-R Discussion
    Last Post: 05-08-2011, 11:12 PM
  2. R32 GTS-T allignment?
    By jboudreau in forum GTS Tech
    Last Post: 01-06-2011, 11:10 PM
  3. Wheel allignment
    By deliberate32 in forum GTS Tech
    Last Post: 07-23-2008, 12:00 PM
  4. Wheel Allignment
    By kneacsu in forum GT-R Tech
    Last Post: 12-19-2006, 02:16 PM
  5. Who can recommend a good shop to get an allignment done??
    By rasppdey in forum Western Region
    Last Post: 01-28-2006, 03:22 AM
