Results 1 to 9 of 9
Thread: Need Elecrtical help
    Nov 2010
    Waterford
    178
    I have installed an aftermarket RPM gauge into my car which is running an rb25det series 2 but can not seem to figure out how to make it work.
    everything is hooked up in means of power, ground ect just not sure where i am supposed to get or how to get the rpm signal for the gauge to work.
    If you know how or where to do this any help is greatly appreciated.
    Brad
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,891
    this is a guess but im assuming your going to have one extra wire after your connected to ground and power and your going to have to splice that into a wire in your ecu harness. but i could be on crack
    GTRCer anthony's Avatar
    Apr 2006
    vancouver island'ish
    951
    Nov 2010
    Waterford
    178
    tried that but didnt work, i might have to pull the tack and make sure its switched right
    Apr 2006
    951
    try this one http://www.paulr33.com/diagrams/rb25det-pinout.pdf this is a different rb25 pinout
    series 1 and 2 pinouts are different from what ive read and #7 is in a different spot in this one
    before you go and take your dash apart
    GTRCer caliber676's Avatar
    Feb 2008
    Burnaby
    1,382
    Don't you wish it was like the old days where you could just splice into a coil. Anyways, your RPM is going to be through an ECU pinout for sure
    Nov 2010
    Waterford
    178
    Quote Originally Posted by anthony View Post
    Ya this is the pin out I have aswell.
    I will try it again and see if it works but if now I will be taring the gauge cluster out and seeing if all is good there.
    Nov 2010
    Waterford
    178
    So I tried the wire and even tried on 2 other tachs to see if mine was no good and I am not getting a tach read out
    is there anywhere else to get a proper tach signal from?
    running an rb25det series 2 on track with a tach is kinda not my cup of tea
    Jul 2009
    Vancity, BC
    647
    tap it on cas and one on lighter to light up then ground
