Results 1 to 2 of 2
Thread: bee*r rev limiter how to install
    GTRCer boostbanshee's Avatar
    Aug 2010
    woodstock, new brunswick
    76
    how do i install a bee* r rev limiter, i got instructions but they were Japanese.
    GTRCer anthony's Avatar
    Apr 2006
    vancouver island'ish
    951
    WIRING
    Yellow Wire - 120' pin on ECU
    Green Wire - 1' pin on ECU
    Red Wire - 12V IGN pin on ECU
    Black Wire - Ground (On PowerFC's you may need to add an extra earth from this pin to the PowerFC chassis for extra earthing).
    White Wire - Attaches to the Handbrake On wire that goes to the dash if you want to activate the Launch Control feature
    ECU pin outs
    R32GTST/GTR & R33GTST/GTR
    Yellow - 41 or 51
    Green - 42 or 52
    Red - 49 or 45
    Black - 50 or 60
    R34GTT
    Yellow - 44 or 45
    Green - 46
    Red - 67
    Black - 25
    R34GTR - I don't have an ECU pinout for this so I can't tell you, hopefully this'll be sorted fairly soon
    CONTROL BOX WIRING
    White Wire Loop - This activates the 2nd white dial which allows you to set a secondary rev limit which only comes on when the handbrake is on and is mostly used as Launch Control. Cut the loop if you don't want to use it
    Grey Wire Loop - Leave this alone, only cut for 4 cylinder cars
    Brown Loop - Leave this alone, only cut if you have a rotary engine
    CONTROL UNIT
    Red Dial - sets normal Engine Rev Limit (see below)
    White Dial - sets Handbrake/Launch Control Rev Limit (see Below)
    Yellow Dial - Sets the Gain or how big the Bang is (0 = off, 1 = very quiet & F = WW3 - try a middle setting and adjust to your peference)
    The 0-F settings match upto these Revs
    0 2500
    1 3000
    2 3500
    3 4000
    4 4500
    5 5000
    6 5500
    7 6000
    8 6500
    9 7000
    A 7500
    B 8000
    C 8500
    D 9000
    E 9500
    F 10000
    TESTING & PROBLEMS
    Normal Test - With the car warmed up (very important) set the Red Dial to 5, the gain at 9 and the white dial to 3 (only if using the handbrake option). Now without the handbrake on gently rev the car and at 5000rpm the car should start back-firing and the red light on the control unit should flash
    Handbrake/Launch Control Test - Put the handbrake on and gently rev the car and at 4000rpm the car should start back-firing and the red light on the control unit should flash.
    If it does then everything is set up and you can now adjust the dials to your own preference.
    Problems - Car doesn't start - swap the Yellow and Green around (shouldn't happen now the instructions are right)
    found it on http://www.skyline-owners-club.com/f...tructions.html
  1. WTB: bee*r limiter
    By JDM101 in forum Want to Buy
    Last Post: 02-24-2011, 02:11 PM
  2. WTB:bee-r rev limiter
    By GTS-James in forum Want to Buy
    Last Post: 02-12-2011, 03:39 PM
  3. Bee*R Rev Limiter install guide?
    By cbileske in forum GT-R Discussion
    Last Post: 01-06-2008, 03:15 AM
  4. Wtb:: Bee-r Rev Limiter
    By joecrack in forum Want to Buy
    Last Post: 10-28-2007, 02:33 AM
  5. Rev limiter?
    By EndLeSS8 in forum GT-R Tech
    Last Post: 03-09-2004, 11:30 AM
