Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Aircare + BOV to atmosphere = HIGH HYDROCARBONS : Solution ?
    kengeroo's Avatar
    Apr 2010
    vancouver
    588
    http://en.wikipedia.org/wiki/Blowoff_valve
    everyone knows this scenario...
    I know it all too well,,
    AIRCARE test count - survey - How many times did it take you to pass ???
    Would the temporary soultion while being aircared , be nuetering the BOV's by pinching off the vacuum hoses to the BOV ??
    GTRCer caliber676's Avatar
    Feb 2008
    Burnaby
    1,382
    It could work, but in the process it may raise your NOx emissions. Emissions are bad that way, reduce one raise another. This is only at BOV release, but aircare doesn't focus on readings during shifting, only at idle and 50-60km/h if i'm not mistaken.
    Dragon Humper's Avatar
    Mar 2007
    Kamloops BC
    1,551
    You can always remove it (them) for the test and then put it back in again. Lot's of people run without BOVs (me included) so it won't be an issue for some short term gain at AirCare time.
    Rides:
    2011 Silverado Crew tow rig.
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    I'd remove atmo bov not just for aircare, but because it can make the car run like a turd if it has MAF's still.
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    best to run recirc BOV w/ a draw-thru MAF
    If you have MAP or blow-thru MAF, atmospheric BOV is fine ( as long as the BOV is before the MAF)
    kengeroo's Avatar
    Apr 2010
    vancouver
    588
    has anyone heard of this ,,, HKS EIDS,,
    seems like the answer to BOV to atm
    http://www.hksusa.com/products/?id=2175
    or perhaps is there some sort of parm in powerFC that compensates for decel, and BOV affects?
    Feb 2008
    Burnaby
    1,382
    Sounds like a good thing to have.
    mfroese's Avatar
    Oct 2007
    Lower Rainland, BC
    284
    I'm not sure if atmospheric BOV is your problem, I have air cared my car with an atmospheric for the past 3 years and results are below.
    I always put the stock exhaust / cat in. During the tests they never activate the BOV since they shift at a lower rpm. They only test at a steady 50km/h and an idle test, both tests should not be releasing air.
    4 door love.
    kengeroo's Avatar
    Apr 2010
    vancouver
    588
    Has anyone used the Apexi NEO,,
    apparently there is a setting that compensates for the BOV Rich problem also..
    oh yeah and on a r33 gtr you need two of the HKS EIDS,,, one for each MAF...
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,700
    With PowerFC, stock ECU you can play with decel settings. Stock ECU has a stop inject, inject, etc settings on decel which can be adjusted to suit when engine is cold, hot, etc.
  1. SSQV vent to atmosphere + air care
    By Prophetic in forum General Skyline Tech
    Last Post: 05-04-2011, 03:37 AM
  2. Solution To Syncro Issues
    By judasentinel in forum GTS Tech
    Last Post: 03-13-2008, 10:40 PM
  3. Failed Aircare - EGR ? High Nox
    By Zulu in forum GT-R Tech
    Last Post: 07-01-2007, 02:13 PM
  4. My solution to the headlight problem
    By Stinky_1 in forum General Skyline Discussion
    Last Post: 03-14-2007, 08:01 PM
  5. Replies: 15
    Last Post: 06-27-2006, 01:47 PM
