Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Code 54 how to fix??
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,054
    Thumbs down Code 54 how to fix??
    pulled my ecu for codes and it just flashes code 54 over and over again.
    this means Auto signal to ECU.
    im not sure what exactly its saying it wrong. is it wiring to the ecu?? the ecu itself?
    how can i fix this.
    im thinking worst case scenario here..but engine harness might be bad?
    info:
    the engine will hardly start. i have to start it WOT and its struggles like a mother ****
    just put in a fresh MAF from ebay, was in shrink wrap and looks brand new.
    A. Nash
    Jul 2009
    Vancity, BC
    647
    i would check for bad ground connections first and start with the ecu harness....
    RSi
    RSi is offline
    GTRCer RSi's Avatar
    Apr 2008
    Surrey, BC
    1,926
    Its an auto car? Not an Auto ECU in a Manual car is it?
    -= PM ME FOR INFO =-
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    ^ That's what it sounds like.
    Aug 2010
    Courtenay , BC
    1,054
    i dont know its the one that came with the car
    if thats the case is there any way to make it work? how could i check.... actually now that i think of it, it says right on the side of the ecu rb20det 5 speed in permanent marker
    A. Nash
    GTRCer aN4rk1's Avatar
    May 2010
    Mississauga
    1,042
    Quote Originally Posted by amnash View Post
    Could be a mistake or a case swap or something. Do you have anyone else in the area that you can maybe borrow a ECU from and check if swapping it helps.
    GTRCer caliber676's Avatar
    Feb 2008
    Burnaby
    1,382
    Rarely an ECU actually fails. Unless you have the incorrect ecu i would start with power and ground like Markc32 said. Then work your way from there checking the circuitry of the systems you think are at fault. Ie awd, abs etc
    RSi
    RSi is offline
    GTRCer RSi's Avatar
    Apr 2008
    Surrey, BC
    1,926
    if its written on the side its been swapped.... are you checking codes through consult? If so that should give an ecu id. What is it please?
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    Mine had a code 54 as well when I had an auto ECU. My car was originally an auto, but converted in Japan. Instead of getting a 5 speed ecu, they just used the auto ECU that was Mines chipped. I've since gone back to a stock 5 speed ECU, but haven't bothered to check for codes lately. Code 54 is fine, I don't believe it means much if anything, my car ran fine with it. I did notice a slight increase in idle speed when coming to a stop though, even with no accessories on. New ecu got rid of that.
    RSi
    RSi is offline
    GTRCer RSi's Avatar
    Apr 2008
    Surrey, BC
    1,926
    Yeah its just telling you that your auto trans may be missing...
  1. Code 21
    By Like_A_Sum_Bootay in forum GTS Tech
    Last Post: 06-15-2011, 03:15 AM
  2. R32 paint name/code
    By RABBIT in forum General Skyline Tech
    Last Post: 05-16-2011, 10:34 PM
  3. ECU Code : A/T Control
    By Southie in forum GTS Tech
    Last Post: 08-11-2008, 06:21 AM
  4. My paint code..
    By TW in forum GT-R Discussion
    Last Post: 06-27-2008, 08:35 AM
  5. code 26:PBR?
    By Jeff Chapple in forum GT-R Tech
    Last Post: 06-07-2007, 01:08 PM
