Results 1 to 5 of 5
Thread: Cams are a TDC but the bottom end wont turn over....help!
    DJ
    DJ is offline
    GTRCer DJ's Avatar
    Nov 2007
    Ottawa
    1,504
    Cams are at TDC but the bottom end wont turn over....help!
    I just dropped in my block and head (rb26) this week .I installed the cams today ,set them to tdc and when I went to spin the crank to line it up with the oil pump mark, it spun for 1/4 of rotation then it just jammed...it woulnt turn over anymore.
    What could possibly cause this?
    the car was out of gear , could it somehow be piston contact with the head/valves...
    need help asap !
    DJ
    DJ is offline
    GTRCer DJ's Avatar
    Nov 2007
    Ottawa
    1,504
    when the block was in without the head ,it spun easily so thats why im thinking its the head.
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    I know with out the head on the block it's really easy to turn over since there's no compression. Did you set your valve clearance? I'm at this stage now and it's holding me back. I heard if valve clearnance isn't set right it the valve may contact piston and cause it to bend. Not sure if that could be why it's not moving.
    DJ
    DJ is offline
    GTRCer DJ's Avatar
    Nov 2007
    Ottawa
    1,504
    Wasnt that,just a silly mistake .thank you problem solved
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    What was the problem anyways? Cam degrees off? Normally its 20* for cams at TDC no?
    www.nelsonmx.wordpress.com
  1. Replies: 0
    Last Post: 04-18-2011, 09:07 AM
  2. Replies: 3
    Last Post: 04-05-2011, 06:31 PM
  3. Gauges wont turn on until i rev high.
    By SpartanGTR in forum GT-R Tech
    Last Post: 04-23-2008, 07:11 PM
  4. Highbeems wont turn off?
    By VancityGTR in forum GT-R Tech
    Last Post: 08-03-2007, 01:08 PM
  5. car wont turn over??
    By maxgohan in forum General Skyline Discussion
    Last Post: 01-12-2007, 12:45 PM
