Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Some very helpful info I stumped upon
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    So even though I am not going to be staying in the skyline scene for much longer I would still love to share with you some info for those who are:
    http://www.gtrusablog.com/2010/05/re...2-r33.html?m=1
    This link actually was very informative and helped out with some basic problems you could run into and also some things you could prevent from happening. I hope this helps
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,891
    nice post. one of the best single links i have seen so far. sums up about 90% of the posts on here
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    Ya I hope this is alot of use to many people here because these questions are asked quite frequently.
    Jun 2011
    Toronto
    1,562
    Sticky this.
    STICKY? Amazing find for the GTR guys. Well done Op. if I'm lucky maybe the author will type up an article for the GTS models as well.
    Because race car.
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    Very nice info there Chris. Good detail to why you should and shouldn't do things. I booked marked it! It's good to have this info even if you know most of it. You never know.
    Although I had one question. They talked about #6 cylinder leaning out. I heard tuners can give you a safe to richen it up a bit more. Im not sure what they do. Can anyone explain that to me please. I want to make sure to tell my tuner about that in case he doesn't know him self.
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,700
    If using stock ECU, richen it up, as don't have individual cylinder fuel trim (I think requires wideband on each runner or just run it tad richer on those cylinders). If using Link, ViPEC, Motec ECU, they have individual cylinder fuel trim feature. Also I think with PowerFC you can adjust fueling on each cylinder.
    If intake plenum is designed correctly (JUN, Hypertune?, etc), don't have to worry too much about it leaning out on 6th. It's due to angle of entry to intake manifold that sends all the air to back of plenum and shape of intake plenum plays a role.
    This is the correct way to design a front mounted intake plenum (similar to JUN, etc) and includes flow data -
    http://forums.hybridz.org/index.php?showtopic=68639
    As you can see where the throttle body is aimed, those cylinders get more air. Then look at stock GTR plenum and it's obvious why 6th gets more air.
    GTRCer PurpleStreak's Avatar
    Jun 2011
    Fort Mac, Alberta
    137
    Hmm, that explains my low compression on #5 & #6 :-)
    Sent from my MB860 using Tapatalk
    Jan 2010
    London, ON
    1,572
    Quote Originally Posted by Skym View Post
    If using stock ECU, richen it up, as don't have individual cylinder fuel trim (I think requires wideband on each runner or just run it tad richer on those cylinders). If using Link, ViPEC, Motec, ECU, they have individual cylinder fuel trim feature. Also I think with PowerFC you can adjust fueling on each cylinder.
    Thanks for clearing that up. I have a stock ecu atm and will probably be using Nistune since that's the cheaper way. Id love to get one of those higher class ecu's tho.
    Thanks Skym always a great help.
    Sep 2007
    South
    6,700
    Nothing wrong with stock ECU. They used it on 640hp R32GTR Group-A racecar engines. But can extract more hp by switching to aftermarket MAP ECU due to less restriction infront of turbo's (remove MAF's with gauze screens).
    The intake plenum doesn't help, but it's common for RB engines to get low compression on 5th, 6th cylinders due to being closest to firewall where heat builds up and head warps. It means stock headgasket needs to be replaced with metal headgasket, metal intake, exhaust gaskets (RB26), head skimmed, etc. Some rebuild engine and fix other problems at same time.
    GTRCer TrevoR32's Avatar
    Oct 2006
    G.T.A
    567
    very nice very nice.
    2009 Infiniti G37XS
    2003 Sentra SE-R Spec V
    2003 Acura MDX (Gave to Brother)
    1991 Nissan Skyline GTR
    2012 Nissan Murano
  1. Replies: 7
    Last Post: 09-16-2011, 06:12 PM
  2. Posted in eastern but any info is good info
    By nimblestix in forum General Skyline Discussion
    Last Post: 07-15-2011, 07:33 PM
  3. GTR ECU Diagnostic Tips!! Very Helpful!!
    By mwracing in forum GT-R Discussion
    Last Post: 06-29-2007, 02:23 PM
  4. Looking for some info
    By GTR_2_NV in forum General Skyline Discussion
    Last Post: 04-19-2007, 05:41 PM
  5. Replies: 1
    Last Post: 09-14-2006, 09:36 PM
