Results 1 to 5 of 5
Thread: Need some help with hicas problems....
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    Ok so here is my predicament... I now have a rb25 motor and everything is hooked up except of or the power steering hard lines to the pump. There is a reason for this though as now that the rb25 ps pump is in there it is not like the rb20/26 with two inlets for the fluid to flow in through since the rb25 hicas was controlled electronically. So what I am asking about is how can I reroute the lines so that I can feed the line into the pump and still have the fluid flowing through the steering rack and also the ps cooler?
    I know it has been done and unfortunately with some research I cannot find it anywhere, and with me trying to finish off every last bit of the car I would like to have the power steering in there since the pump and a brand new belt are already installed!
    Thanks in advance to anyone that can shed some light on this
    C-unit's Avatar
    Jan 2005
    Richmond, HongKong
    2,951
    If you don't want to run custom lines, bend the original lines and make them fit. It'll look messy as hell though.
    not so much a RB25 but it's the same idea how non-hydraulic hicas are hooked up. This is from a non-hicas S13.
    輝く ヘタクソの星 -- 訓啦柒頭
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    Thanks charles. I will need to do some farting around with the system. I tried re routing it a while back before I stopped working on the car and then just totally lost my game plan. I would prefer to have ps seeming how my car will be a dd
    C-unit's Avatar
    Jan 2005
    Richmond, HongKong
    2,951
    Easiest way to do it is to get a chasebay power steering line/reservoir kit.
    輝く ヘタクソの星 -- 訓啦柒頭
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    Where could I get that Charles?
  1. FS: Tomei HICAS Lock 2 (Eliminates HICAS)
    By dk89 in forum Parts for Sale
    Last Post: 05-10-2011, 08:51 AM
  2. Replies: 12
    Last Post: 04-05-2011, 09:32 AM
  3. hicas problems w/o moving
    By TrevoR32 in forum General Skyline Discussion
    Last Post: 02-01-2008, 07:30 PM
  4. HICAS problems
    By assman in forum GTS Tech
    Last Post: 07-29-2007, 07:24 PM
  5. Hicas light on, hicas removal bar in place.
    By Inline Slut in forum GTS Tech
    Last Post: 12-05-2006, 11:19 AM
