Results 1 to 7 of 7
Thread: question regarding injector upgrade on rb25
    GTRCer 2FAST4U-94r33's Avatar
    Jun 2009
    kanata
    8
    Hey guys need some input on investors. Looking to upgrade injectors/fuel pump on my r33 gts. Already have upgraded splitfire coil packs and fmic. Wondering if I do go ahead with this purshase and tune the car with a stock turbo if I will be fine. My concern is the stock turbo with all these mods wont hold up.
    Any input is appreciated
    Thanks
    cschepp's Avatar
    Jan 2008
    _________________
    4,318
    I got mine switched over with powerhouses kit. Joe and his team made it easy to do and it looks great. You can contact joe at powerhouse racing and he can help you out with that. Great kit!
    GTRCer BrianV8's Avatar
    Aug 2008
    Kamloops
    2,050
    if you have an S1 turbo keep the boost under 1 bar
    if you have an s2 turbo keep the boost under 12 pounds and you should be fine. If you need more flow than that start looking at upgrading
    Jun 2009
    kanata
    8
    S1 s2???
    Aug 2008
    Kamloops
    2,050
    series 1 or series 2 motor, s1 94 and older s2 is 95 and newer i believe is the spread
    Jun 2009
    kanata
    8
    Well car started off life as a Non turbo according to vin. The engine cover is bubble top room I believe series one. I guess I'd have to research the engine vin. Regardless I'm only looking tu run 9.5psi on high boost and 6 on low with my boost controller. do you think I would have any problems with over fueling?
    Thanks
    Jun 2010
    Ottawa
    368
    Factory it runs 5psi and 8psi with its two stage boost control. If you only want to run 9.5, skip the boost controller and just put an rb20 wastegate actuator on it and call it a day.
  1. rb25 trubo upgrade
    By aman1515 in forum Want to Buy
    Last Post: 09-15-2011, 08:22 PM
  2. RB20DET Injector Upgrade
    By trickey1991 in forum GTS Tech
    Last Post: 07-12-2011, 12:01 PM
  3. Upgrade turbo for an RB25
    By bnsportsr33 in forum GTS Tech
    Last Post: 05-19-2011, 12:03 AM
  4. FS: RB25 Turbo Good Upgrade For RB20
    By canadianskyline in forum Parts for Sale
    Last Post: 03-11-2008, 11:15 AM
  5. exhaust upgrade question
    By Ti Pit in forum GT-R Tech
    Last Post: 07-25-2005, 08:07 PM
