Results 1 to 10 of 10
Thread: Cold startup whine - RB25DET
    GTRCer Ukyo8's Avatar
    May 2007
    Calgary
    45
    fixed
    GTRCer Kyxxer's Avatar
    Sep 2011
    Eastern Ontario
    21
    drain all the fluids and start fresh, then its a process of elimination
    after being shipped and more then likely sitting in a car lot for sometime before being put on the ship, the fluids can spoil (lose viscosity) ..... just an idea
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,054
    have you done an oil change since it was imported? might be some crazy thick oil in there like 10w60. skym used to run really thick oil, ask him if he had anything similar. what are the spec on the oil pump? and history of car? worst case scenario: previous owner drove the piss out of this car and cracked oil pump gears from banging the limiter.(i dont think this is it. but its the only thing i can think of that could go wrong with the pump)
    for anyone: is there actually any signs of a oil pump on its way out?? besides your engine blowing up
    A. Nash
    Aug 2010
    Courtenay , BC
    1,054
    and use a long screwdriver to listen around the engine bay and find where its coming from
    A. Nash
    GTRCer BrianV8's Avatar
    Aug 2008
    Kamloops
    2,050
    powersteering or ac pump?
    GTRCer BenC's Avatar
    Jun 2007
    Lethbridge, Alberta
    964
    sounds like power steering pump whine
    May 2007
    Calgary
    45
    fixed
    Jul 2009
    Vancity, BC
    647
    oil pump will not make any noise its either working or not......listen to all ur pullies
    Jul 2009
    Vancity, BC
    647
    if ur oil pressure sender is still original replace it...just so u know u have actual oil pressue all the time
    May 2007
    Calgary
    45
    fixed
  1. Replies: 9
    Last Post: 12-24-2011, 12:21 PM
  2. timing belt whine...
    By lloydxmas in forum General Skyline Tech
    Last Post: 09-15-2010, 03:22 PM
  3. loud whine inside car?!?
    By bowes in forum GT-R Tech
    Last Post: 01-21-2008, 04:20 PM
  4. Cold Air intakes
    By specialedition in forum General Skyline Discussion
    Last Post: 11-13-2007, 05:22 PM
  5. fuel pump whine
    By Endless604 in forum GTS Tech
    Last Post: 06-28-2006, 01:37 PM
