Results 1 to 6 of 6
Thread: R32 GTS Driver window help.
    GTRCer Jezu21's Avatar
    Oct 2008
    Peterborough, ON
    150
    So I was out for a drive yesterday, and as I started to put my window up, the window fell straight down and will not come back up. So I assume it is off the track.
    Anyone know how I can fix this?
    It looks like there is a peice of thin cable all messed up inside the door too, which I assume is part of the window mechanism.
    Any help is greatly appreciated, as it's supposed to rain soon and my garage is full
    GTRCer amnash's Avatar
    Aug 2010
    North Van Island
    1,518
    i would just take the door panel off and have a look. if your handy with a wrench you should be able to see what wrong and hopefully just put the window back on its track
    - Adam
    build thread :
    Oct 2008
    Peterborough, ON
    150
    The cable that is all twisted up is part of the regulator and it snapped.
    So I do believe I need a new regulator.
    GTRCer evolution23's Avatar
    Mar 2011
    Slurrey, BC
    312
    Quote Originally Posted by Jezu21 View Post
    Had this same issue with my r32 about 15 minutes into a 7 hour drive. i was told its not possible to just re-wire it so i ended up replacing the regulator assembly as well. hung my window up with tape and wire until i could track down a new regulator.
    Nitrous is like a hot girl with an STD. You know you want to hit it but your afraid of the consequences.
    May 2009
    Ottawa, ON
    320
    The wire should run over a series of pulleys and it is possible to re align them unless a part of the regulator or pulleys are broken. Should only take about 15 or 20 mins to take the door pad off
    Oct 2008
    Peterborough, ON
    150
    Quote Originally Posted by evolution23 View Post
    Hey, could you tell me where you got the regulator from? I'm gonna need one so if you could point me in the right direction I'd appreciate it!
  1. WTB: R32 Driver's side window rail
    By LettoGTST in forum Want to Buy
    Last Post: 10-06-2011, 01:22 AM
  2. WTB: driver side window regulator
    By bakerman1978 in forum Want to Buy
    Last Post: 06-16-2011, 06:29 AM
  3. Looking for r32 driver window.... ASAP
    By Whiteivory in forum Want to Buy
    Last Post: 05-23-2011, 03:52 AM
  4. driver side window motor
    By skylinemagic in forum Want to Buy
    Last Post: 09-04-2008, 11:45 AM
  5. Vandalism - Need Driver Quarter Window!!!
    By krispenev in forum GTS Discussion
    Last Post: 07-15-2008, 08:55 AM
