Results 1 to 7 of 7
Thread: Steering solid adapter !? what's that?
    Dec 2007
    Quebec
    3,942
    http://www.rhdjapan.com/yanack-steer...1-cefiro-56058
    Is it hard to replace? for 40$ it seems like a great mod but does it really do what it say and does it take 5 hours to replace?
    thanks!
    GTRCer danwit's Avatar
    Sep 2009
    hamilton
    286
    Its only 4 bolts, i doubt very highly it would take 5 hours. Its certainly a pain to get at tho.
    I canz take this corner at 195k cause i gots AWDZ. Get real.
    Daryl @ RightDrive's Avatar
    May 2004
    Toronto
    8,629
    It would take around 5 hours depending on who is doing it. The entire steering column has to come out.
    RightDrive Inc. Parts Manager
    RB26 Clear Timing Covers!
    Sep 2009
    hamilton
    286
    Quote Originally Posted by Daryl @ RightDrive View Post
    Really? I was looking at doing it, it looks like you could just take the bolts out and swap the bushing..
    May 2004
    Toronto
    8,629
    I think the issue is that you cannot slide the column up to clear the bolts, hence taking off the column.
    I didn't watch when we did it last time so I'm not sure.
    GTRCer caliber676's Avatar
    Feb 2008
    Burnaby
    1,784
    You'd need to at least unbolt the steering column mounts and detach it slightly I order to remove and install the bushing. The problem with these things is that they are a tight fit. I couldn't get mine on unless I froze the 4 metal plugs and heated the bushing. Even then I had to use a dead blow hammer. If you manage to loosen the lower steering column that splines into the column and separate it from the top half you can theoretically just r&i that. Keep in mind the fasteners for that bushing are pretty tightly secured and I believe thread locked as well
    Dec 2007
    Quebec
    3,942
    thank you guys! Guess I will forget that mod
  1. Solid sr20 litters
    By rolyaT in forum Off Topic Marketplace
    Last Post: 11-22-2011, 12:46 PM
  2. Nismo solid vs. oem shifter
    By APL in forum GTS Tech
    Last Post: 01-14-2011, 07:14 AM
  3. RB20DET solid lifters
    By jdmnewf in forum GTS Tech
    Last Post: 01-05-2007, 11:56 AM
  4. Replies: 4
    Last Post: 11-22-2005, 09:10 PM
  5. hub adapter for momo steering wheel
    By JZ in forum GT-R Tech
    Last Post: 10-29-2005, 09:50 AM
